Results 1 to 30 of 39
  1. hey there Folks... umm.. I've been trying to rip from "Daisuki.net" lately and have got nothing so far. It would have been easy if it had no DRM protection in it.
    HDS encryption and Flash access DRM protection are both acting up..
    Anyways.. I've been trying to RIP this video for starters.... Help me out folks .. thanx
    " http://www.daisuki.net/anime/watch/KurokosBasketball3/SUc "
    Please help me out ^_^
    Thank You.
  2. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Just to know, the site accepts what country? because it has local restriction
  3. I can't see any restrictions in my country.... just use a Proxy/VPN... should stream normally.... but, the question is about RIPPING...
  4. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    It's really strange, the site is in english but in a country who talk english, it doesn't work??
    I can't test softwares if I can't play the video, sorry, maybe the episode is available on other streaming site or youtube
  5. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Oh, ok if you can play the video, ask in the right place where they talk of ripping if you want
  6. enter video on site use adblock plus firefox addon click ABP icon click open blockable items search for f4m url copy and change parameters
    http to https , z to i and manifest.f4m to master.m3u8
    http://bngn-vh.akamaihd.net/z/43383936/35470338/smil/PT/00005/562242435397364.smil/manifest.f4m?hdnea=st=1422382455~exp=1422382755~acl=/*~hmac=c561c961b389fe4cb274317f2f7086b4d086eae3227 2c8fd67aa68bd08a8634a&g=KWHXDBJEXEJF&hdcore=3.2.0
    change to
    https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/PT/00005/562242435397364.smil/master.m3u8?hdnea=st=1422382455~exp=1422382755~acl=/*~hmac=c561c961b389fe4cb274317f2f7086b4d086eae3227 2c8fd67aa68bd08a8634a&g=KWHXDBJEXEJF&hdcore=3.2.0
    and use livestreamer to download it
    livestreamer "hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/PT/00005/562242435397364.smil/master.m3u8?hdnea=st=1422382455~exp=1422382755~acl =/*~hmac=c561c961b389fe4cb274317f2f7086b4d086eae3227 2c8fd67aa68bd08a8634a&g=KWHXDBJEXEJF&hdcore=3.2.0" best -o video.ts
  7. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Cool! I knew someone will find the solution! you're lucky, Scavvy.
    Could you help me to download a video too, please?
  8. Originally Posted by CristianoA View Post
    thanx man.. but, I get an error...
    "403 Client Error:Forbidden" ....
    This is what I tried with Livestreamer :
    livestreamer "hlsvariant://https://bngn-vh.akamaihd.net/i/43383936/35470338/smil/US/00005/562242435397364.smil/master.m3u8?hdnea=st=1422536348~exp=1422536648~acl=/*~hmac=5ac39bf847e9e464c5cabfc1d78f0eb8b24ff3b89a81833ad3af735ccae797a8&g=TBCEFQIVEFBA&hdcore=3.2.0" best -o video.ts
    Screenshot :
    Thank You
    Jan 2015
    Kolkata , India
    Did the Solution work Scavvy ???
  10. Originally Posted by Scavvy View Post
    Screenshot :
    Thank You
    no problem here maybe try to use url with http and then https
  11. Originally Posted by CristianoA View Post
    Ok.. everything is fine now.... I messed up lol... Was using Proxy in my browser and no VPN/Proxy as on my system.. worked like a charm!! Thanx a ton man !! ^_^
    Mods please close the thread if you want ^_^
  12. didn't need that... already ripped the subs....
    thanx anyways
  13. Hey, I wanted to ask for help but after a few attempts it worked
    I kept getting 403 error but I was starting from the wrong link.
    I will then download the subtitles. Any advice about the best way to encode video and subs to make it hardsub?
    Thanks!
    Aug 2012
    United States of America
    Thanks!
    I apologize for not directly answering your question. I just wanted to say the fastest, cleanest and easiest way would be to use mkvmerge to mux the audio,video and subtitles into an .mkv container. Just make sure you have compression set to none for audio and video. Then make sure you have the subtitles flagged as default. Same result. Very little work. Someone please correct me if I am wrong because this topic interests me. I have never ripped from Daisuki before.
  15. Originally Posted by Jodensai View Post
    Thanks!
    Thanks for the answer
    About the ripping from Daisuki it stopped and I now get the 403 client error again
    Same code as when it worked..
ID:	31203Click image for larger version
  16. Originally Posted by Cibiz View Post
    Thanks!
    [Attachment 31203 - Click to enlarge]
    [Attachment 31204 - Click to enlarge]
    hi the code expire with time
    .............................hdnea=st=1422536348~exp=142254567........
  17. Hi, im very interested in this topic myself. I am trying to rip a video from daisuki using livestreamer but im not getting anything, not even an error. The process seems to complete but I cant find the video anywhere. Where is the video supposed to download to on my computer? I havent changed any settings so everything should be default.
    Also, im on a restricted country but im using a proxy to see the page and get the URLs. Do I need to use a proxy also for ripping the video via livestreamer?
    Thank you.
  18. Originally Posted by supercain View Post
    Thank you.
    http://docs.livestreamer.io/cli.html#cmdoption--http-proxy
  19. So its necessary to use a proxy in order to get the video from daisuki from my location?
  20. Originally Posted by supercain View Post
    yes you need use proxy with livestreamer
  21. Alright, I will do so. Also, what format is the video you get from daisuki?
  22. Originally Posted by supercain View Post
    best quality Opening stream: 1080p (hls) so .ts format
    you need have a good proxy with good bandwidth for best quality
    other quality Available streams: 1080p (best), 360p (worst), 480p, 720p
  23. Thats very useful. Thank you for your help. I appreciate it.
  24. awesome thread thanks
  25. Member
    Oct 2015
    Kuala Terengganu Malaysia
    Could Someone Help me..this what i got....please im a malaysian...im so confused..i dont know what is wrong with it..please help me..
  26. Originally Posted by zerox hikari View Post
    [Attachment 33941 - Click to enlarge]
    maybe you use a proxy or a vpn to access on your browser
    If this is the case you must use the same proxy or vpn through your command prompt
  27. Member
    Oct 2015
    could you help me biezom-san...i have try it about a thousand time..i dont know where is the wrong..could you show and teach me what is the wrong thing here.. onegaishimas
