So im using MSI afterburner wiht the AMD VCE H.264 Encoder and im running into some problem editing that file, most programs crash or cant read the file at all and i have to reencode it wiht Handbrake. Can anyone suggest me some tips or maybe a fix for that ? Heres the MediaInfo. i tried x264vfw but somehow the video lags sometimes or keeps slowing down and my fps is wayyy better wiht the amd vce.
Code:ncoded date : UTC 2015-01-18 20:19:04 Writing application : MSIAfterburner.exe v4.0.0.4604 Writing library : RivaTuner media encoding library v1.38.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Codec ID : V_MPEG4/ISO/AVC Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Language : English Default : Yes Forced : No Audio ID : 2 Format : PCM Codec ID : A_PCM/INT/LIT Duration : 52mn 40s Bit rate mode : Constant Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Language : English Default : Yes Forced : No
Can't you record in constant framerate?
What is the video container? mp4,ts,mkv?
