I want to rip a video, but the Adobe HDS stream is FlashAccess DRM protected. There are RTMP links available also without DRM, but I can't get an auth code to connect to those links. Every time I load the page (different browsers, different Flash versions) I always get the HDS auth codes and not the RTMP auth codes.
Is there any way I can force the RTMP stream to play instead of the HDS stream? Should I block f4m files?
For example:
http://www.tntdrama.com/videos/cold-justice/season-3/episode-3/burned-fairview-park-oh.html
You may need a US TV subscription to get access, but there are online accounts available if you need one (http://freebie-nation.org/index.php?threads/directv-with-21-_-172-_-53-_-27-_-63.88230/)
