  1. Is there a specific brand to look for? Or a good place to buy them from? I'm trying to get some clear/standard DVD cases that can hold two discs, but I don't want some cheap flimsy ones that are going to break easily.
    Nov 2003
    West Texas
    Amaray is probably the best known brand for high quality cases. http://www.tapeandmedia.com/amaray_dvd_case_clear.asp
    You can get the insert that snaps in place if you need more than one disc per case. Amaray isn't particularly inexpensive.
  3. Sears.com has some good deals on double cd jewel cases. They look cheap from the pics but, I got some maxell ones from kmart in the actual store and they are built alot better then the regualr single jewl cases.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Who cares. Nobody is looking for or asking about CD cases.
    May 2003
    Peterborough, England
    I second Amaray but where you get them from depends on where in the world you are as you don't say. I get mine from www.svp.co.uk but that is no good to you if you aren't in the UK.
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I get my 4 & 6 disc cases from here: http://www.genesysdtp.com/dvdbox.htm
    Google is your Friend
