  1. Hello, I'm using Evaer software to record Skype videocall, I'v been using it for a week and everything was fine, today I recorded a videocall and it was fine, straight after that, I made another videocall, I recorded and I got 2 output files, the first showing a green screen, the second one showIng the actual videocall but motioned very fast, it was originally 7.12 min long but the video captured everything in 1.35 min at a 156 frame rate!After that I restarted Evaer and Skype, trying out again, but I keep on getting 2 files (I see that when recording it says 2 streams recording while I setted to record remote webcam only), the first is green the second with the videocall but crazy framerates, (28, 38, 100, while i'm recording at 30fps). Iv been trying with Xvid and Avi, X264 and Mp4 and it doesn't change anything. It's really strange cause all of this did happen suddently, I didn't change any settings at all. What do you think could be the reason?I'm using windows 8.1, thanks so much
    Maybe just try reinstall evaer?
  3. Hi, I restarted and it worked fine, but any ideas to what is happened?something about my pc or the program itself?that was very odd, it was like it was finding two streaming sources while there should have been one.
