I had to reinstall Win7 and now movies won't play in WMP. Everything I can find about file association methods in Win7 ignores the IFO,BUP, and VOB extensions. I used to be able to click on any of those files and it would open WMP. How can I make it do that again?
Results 1 to 17 of 17
How did you try?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Start->Default Programs->"Associate file type or protocol with a program" shows what default program is associated with an extension and allows users to change the default program assigned to it. If an extension isn't listed, then it isn't associated with any programs.
There is another way. Right-click on a VOB, IFO, or BUP file in Windows Explorer. Select "Properties" from the context menu. The "General" tab on the "Properties" window that appears has a button that allows setting or changing the program association. Did you try that? -
That explains that.
Aha! Now THAT works! Thanks a lot!There is another way. Right-click on a VOB, IFO, or BUP file in Windows Explorer. Select "Properties" from the context menu. The "General" tab on the "Properties" window that appears has a button that allows setting or changing the program association. Did you try that? -
"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
I've used it off and on for years and don't really care for it. Not sure why. On the other hand, it's really stupid that I can't even open my video files in
