this machine has been changed, so the old 9999 hack no longer works. the setup menu functions and the remote are different. the date on it is september 2014. the 9999 hack works on machines up to 2013. i like these because they are cheap & available locally, so i'd hate to give them up. does anyone know the new hack, if there is one? thanks in advance for any help.
	The region hack for the d200b dvd player is open tray, press 5,1,6,8 on remote control and you'll see a menu, go to region and press enter button, select region 1 to region 6 number then press enter and press the menu button to exit.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
