    Sep 2006
    I apologize if this has been asked before. I have an MKV file which is 9.82GB. It is 1080P and has DTS 6 channel audio. I want to create a disc that I can play in a blu-ray player without quality loss, and to preserve the DTS. Should I burn it to a 25GB blu-ray disc which seems wasteful, or can I shrink it to fit an 8.5GB DL DVD with virtually the same quality? Also, what program do you recommend to do this both for a blank bluray disc and a blank DL DVD. Thanks for your help in advance.
  2. I'd spend the extra 50 cents and not waste my time re-encoding to something that may or may not work.
    May 2014
    Memphis TN, US
    It depends on how the MKV is configured. 1080p is not valid for BluRay, which has very specific standards and parameters. At 1920x1080, only interlaced 29.97 NTSC or 25fps PAL are allowed, or progressive at film speeds 23.976/24 fps .
    https://www.videohelp.com/hd#tech
    http://forum.doom9.org/showthread.php?t=154533
    Virtually? No way. Maybe "nearly", depending on how carefully you re-encode.
    TMPGenc Video Mastering Works, for one. There are very few free encoders that will suffice for BluRay.
    For DVD you can try AVS2DVd. DVD will not accept 1080p, and is usually interlaced or telecined. https://www.videohelp.com/dvd#tech
    The capacity of a DVD+R DL disc is actually a little less than 8.5GB. Consider space for formatting, indexing, etc., and the fact that the actual "GB" isn't really 1 billion bytes (1GB) but is 1024x1024x1024 bytes = 1073741824 bytes, so the actual capacity is 7.92 GB.
    You can burn an mkv to a BluRay disc as "data". Some players will handle it, some won't. We need more information about your source mkv.
    - My sister Ann's brother
    Nov 2003
    West Texas
    BD Rebuilder can accept MKV files as input and give you either a Blu-ray/AVCHD format movie that will fit onto a double layer DVD, or you can convert to DVD-video.
    If you are going to make DVD-video, you need to set the Mode to Alternate Movie-Only Output-->DVD-9. If going to Blu-ray/AVCHD, you need to go to Settings-->Output Options-->BD9.
    To import the MKV, click on File-->Import-->Video Files.
    Edit: Keeping the DTS audio would take some extra steps in Setup. You need to put a check mark in the box to NOT convert DTS to AC3. I would also put a check mark in the box to keep HD audio in BD25/Alternate intact. Do not put a check mark in the box to make a strict AVCHD for BD5/9. That should work to keep the DTS audio.
    I don't think you'll be able to keep the DTS audio in BD Rebuilder when making a DVD-video however.
    Nov 2003
    West Texas
    I should also mention that BD Rebuilder could also convert the MKV to Blu-ray and use the 25gb disc size output. To keep the DTS audio follow the steps in Setup that I've already outlined.
    I've stopped using DL DVD's entirely, since Blu-ray media has come down in price, not to mention the fact that the vast majority of stand-alone players will be able to play this Blu-ray movie from a burned BD disc, and that is not a certainty when playing Blu-ray format on a DVD.
    Sep 2006
    Here is the MediInfo of the MKV clip:
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 9.83 GiB
    Duration : 2h 14mn
    Overall bit rate : 10.5 Mbps
    Encoded date : UTC 2015-01-13 22:05:16
    Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
    Writing library : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 14mn
    Bit rate : 8 949 Kbps
    Width : 1 920 pixels
    Height : 808 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.241
    Stream size : 8.21 GiB (84%)
    Writing library : x264 core 144 r2525 40bb568
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8949 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 2h 14mn
    Bit rate mode : Constant
    Bit rate : 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.42 GiB (14%)
    Language : English
    Default : Yes
    Forced : No
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Title : English-Forced
    Language : English
    Default : Yes
    Forced : Yes
    Menu
    00:00:00.000 : en:00:00:00.000
    00:07:58.228 : en:00:07:58.228
    00:20:24.682 : en:00:20:24.682
    00:26:38.931 : en:00:26:38.931
    00:37:26.035 : en:00:37:26.035
    00:43:24.060 : en:00:43:24.060
    00:51:59.408 : en:00:51:59.408
    01:01:20.302 : en:01:01:20.302
    01:13:46.547 : en:01:13:46.547
    01:18:29.705 : en:01:18:29.705
    01:26:21.802 : en:01:26:21.802
    01:29:50.427 : en:01:29:50.427
    01:35:39.192 : en:01:35:39.192
    01:48:12.111 : en:01:48:12.111
    01:57:49.980 : en:01:57:49.980
    02:00:41.609 : en:02:00:41.609
  7. Banned
    Freedonia
    1080p IS indeed valid for BluRay. 1920x1080 "progressive at film speeds 23.976/24 fps", to quote your exact words, is 1080p.
    Anyway...
    The OP's MediaInfo post was helpful. His video is 1920x808 which is not valid for BluRay. It would have to be re-encoded to 1920x1080 output. My suggestion would be to just burn the MKV file as is to a BD disc as a data disc burn because most BluRay players should be able to play the MKV file from disc without any problems.
    Sep 2006
    Will do. Thanks.
