Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
Results 1 to 12 of 12
    Jan 2004
    I currently have these speakers and small subwoofer from Altec Lansing:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16836113016&FM=1
    obviously, I am NOT doing any kind of surround sound editing. I like these speakers, except they get a buzz which I guess is some kind of interference. Can anyone recommend a better set of speakers? I know that is kind of a broad question and that there is super high end audio equipment available for video editors, but I am not that mission critical, just need decent audio reproduction to hear the sound..
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then get headphones.
    Jan 2004
    I don't want headphones
  4. Banned
    Oct 2014
    Northern California
    If you want budget you could consider M-AUDIO with a SBX 10 subwoofer with two BX 8 (or if you are sub budget two BX5) monitor speakers. Obviously you also need a good quality D/A converter.
    The Altec Lansing set is totally not suitable for any kind of sound editing.
    May 2014
    Memphis TN, US
    You must be accustomed to the usual Walmart (crummy lousy horrible nasty) headphones. If the pros use studio headphones (but not from crummy lousy horrible nasty Walmart), there must be reasons. And there are reasons, lots of 'em. If you want great monitor speakers, you'll have to spend tons of cash for studio monitors, besides rebuilding your editing environment acoustically. And you'll have to sell your Harley for the cash to buy amps to run them.
    Or you can get away with under a hundred clams for audiophile-qualkity phones made specifically for the kind of low-output amps in PC work. http://www.audioadvisor.com/prodinfo.asp?number=GRSR80E
    Otherwise put up with whatever you can find from the typical big box outlet. They're all pretty much alike, just some are bigger than others. Or try these popular smaller ones, the M_Audio AV40's http://www.amazon.com/gp/product/B0051WAM64?tag=thewire06-20&linkCode=as2 . Other M-AUDIO stuff is also pretty good.
    Or if you just want loud and don't mind throwing away your heard-earned money for overpriced mediocrity, try Bose.
    - My sister Ann's brother
    Jan 2004
    The M-AUDIO AV 40 speakers don't look too bad for $149, seem to be the best seller at B&H so I'll probably go for those. What would be the best way to connect them to my sound card? Sound card just has a regular mini stereo plug. I see they have TRS and RCA, and I guess I have to use speaker wire to connect one speaker to the other?
    I just saw that there's an AV 30 as well, with a 3" Woofer.. How do you know if you need a 3" or 4" woofer?
  7. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Better quality headphones and external monitors both help to make accurate judgements of your audio edits. Anyway, that you don't want headphones at least doesn't predispose you to getting any of that overrated, over-hyped, very expensive, poor frequency response (as in not flat) beats crap.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  8. I have M-AUDIO AV30 speakers that are quite tolerable, but for editing I use Sennheiser HD439 headphones, which sound so much better than the speakers.
    Jan 2004
    After doing a lot of reading of reviews, I'm not so sure about the M-AUDIO. More than a handful of people across various sites said that the product was good "while it lasted" meaning that many people experienced failure much sooner than expected.
    Mar 2011
    Nova Scotia, Canada
    I don't necessarily read those reviews closely. Naturally most everyone who has a failure complains. Most people who are happy don't bother submit reviews. It's not exactly a scientific study.
    For value Behringer is also quite good. I use one of their usb sound cards as an external dac. It was $35 and I'm flabbergasted at how good it sounds.
    Jan 2004
    I think I'm going for the Mackie CR4; I know they're a solid brand and make stuff to last and the reviews are great too.
    Jan 2004
    Mackie speakers arrived today, so far I think they sound great, definitely a major upgrade from the old Altec Lansing system.
