Hi,
I'm using VOB2MPG PRO 3.2.2000, and regularly it produces the correct mpg out of VOBs.
But for some DVDs (e.g. Clear History), it says:
20:37:55 Extracting chapter: 8... Done.
20:37:55 Extracting chapter: 9...
20:37:55
20:37:55 ************* VIRTUAL FILE ERROR *************
20:37:55
20:37:55 Chapter: 9
20:37:55 Cell: 0
20:37:55 LastSector: 2983022
20:37:55 endPos: 6109231104
20:37:55 _VOBFile.Length: 6107725824
20:37:55
20:37:55 Info: Either there is a file missing or a file is shorter than expected!!!
20:37:55
20:37:55
20:37:55 Extracting chapter: 10...
20:37:55
20:37:55
20:37:55 Chapter: 10
20:37:55 Cell: 0
20:37:55 LastSector: 2983027
20:37:55 endPos: 6109241344
20:37:55
20:37:55
20:37:55
20:37:55 Finished Processing...
And the output file will be 4 minutes shorter, than it should be.
If I say in a command line:
> copy /b *.vob file.mpg
Windows produces the correct mpg (but with all the audio tracks).
What is the problem with VOB2MPG PRO?
Please advise (or fix it).
Thanks,
Laszlo
With DVD decrypter 3.5.4.0
But it's all after any DVD protection, since I can copy them together...
