Hi all,
Is it possible to edit a blu ray menu? If so, how would I go around doing that? I'm trying to add a subtitle stream, and add subtitle options into the menu.
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEY!
Easily? Nope. You must reauthor the entire bd. Use for example tmpgenc authoring works, https://www.videohelp.com/tools/sections/authoring-bd-hd-dvd
okay, thanks.
