Hi
I'm ok at ripping and converting DVD's to VCD and SVCD, however, I recently d/l'd some films, notably Blade 2 and Jeepers Creepers. They are both in 2 parts and play fine through media player. When I try to load em into Tpmgenc it comes up with unsupported file format blah blah and wont work. I've tried loading various codacs and gone through the VCDhelp instructions with a fine toothcomb but to no avail. I've got a prog called AVI2VCD to work and it encodes but has no options like TMPGENC to alter quality and other settings.
Any ideas on what i'm doing wrong?
Cheers
Willy
Hi
Try this out.
In Tmpgenc, choose options - environmental setting - VFAPI plugin. Change the priority to 1 for Directshow Multimedia Reader, and 0 for all the others.
Hope it solves your problem.
Sad Luke -
Cheers i'll try that when I get back from work.Originally Posted by sad_luke
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
