Hi,
I have 7:1 dvd duplicator and want to add copyright protection while burning the disc. I find "External USB 3.0 port for Copystars SATA CD DVD blu ray Duplicator Disc copier" (screenshot attached) ... Its features mentioned on amazon site are :-
will this hardware help me to add copyright protection if i connect it to my burner through usb and then burn dvds with copyright protection on my duplicator ?Code:USB 3.0 to connect duplicator to PC One of the burner drive cannot be connected manual operation of mechanical toggle switch to control on/off When off- normal duplicator operation When On- the burner drive connected to PC via USB become external drive .
pls share your views....
regards
John
Effective protection - No.
If Hollywood can't pull effective protection off with commercial pressing plants and tens of million in budget to develop schemes, what chance do you realistically expect to have with a home duplicator from Amazon? -
You can't even use "ineffective" protection, USB or no USB.
USB has nothing to do with it.
Hollywood protections are built upon encryptions with the keys situated in non-user-generated areas of the disc. These areas are only available when creating PRESSED (replicated) discs, not BURNED (duplicated). Duplicators of ALL kinds can only access user-generated areas. No exceptions.
Scott -
That does not even describe 'copy protection'. Its just a toggle switch from duplication to a plain external drive.
