Hello!
Which is the best Android and IOS Smart phone video capture applications?
Which has the most capture and compression options?
Thank you for your reply!
Results 1 to 15 of 15
capture for what usage/purpose?
what are your criteria for "best"?
most don't have more than the slimmest of options (sd/720/1080, auto/manual iso+gain, AVC bitrate tiers).
read my post in the previous thread dealing with 4k CFR 60Fps shooting options for devices.
Scott -
I haven't found any for Android, still looking.
Extraordinary claims require extraordinary evidence -Carl Sagan -
@Stears555, did you look at my previous posts? It lists apps that do most of those things.
You won't find an app that does them all for the simple reason that no past or present phone has the hardware ability to adjust focus. And that for the simple reasons that they don't have a multiple, moveable lens system and their sensor is small which renders nearly everything in focus.
Scott -
Additional movable lens system: Watch it from 1:40 https://www.youtube.com/watch?v=sIVmjE6f6oA
Do you think that bitrate hack would work?
https://www.youtube.com/watch?v=JqocwWGGrNE
Description: 4k video on a cell phone can good! By default 35mbps is too low for any motion to stay sharp. Most 4k cell phone video looks worse then full HD. Now you can hack your phone to more than triple the bitrate. -
That requires rooting.
