hi!
I'm trying to import a mpeg in premiere. I had no error message on importing but I have a white screen on timeline and it has no sound. If I press play it plays also as a white no sound screen.
anyone could help?
here are the information from mediainfo:
General
CompleteName
Format : MPEG-PS
FileSize/String : 140 MiB
Duration/String : 1mn 8s
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 17.2 Mbps
Video
ID/String : 224 (0xE0)
Format : MPEG Video
Format_Version : Version 2
Format_Profile : Main@High
Format_Settings_BVOP/String : Yes
Format_Settings_Matrix/String : Default
Format_Settings_GOP : Variable
BitRate/String : 16.6 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 25.000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.319
TimeCode_FirstFrame : 00:00:00:00
TimeCode_Source : Group of pictures header
Gop_OpenClosed/String : Open
StreamSize/String : 134 MiB (96%)
Audio
ID/String : 192 (0xC0)
Format : MPEG Audio
Format_Version : Version 1
Format_Profile : Layer 2
BitRate_Mode/String : Constant
BitRate/String : 320 Kbps
Channel(s)/String : 2 channels
SamplingRate/String : 48.0 KHz
StreamSize/String : 2.59 MiB (2%)
thank you in advanced!
Are you sure it isn't 1min+8sec of properly-encoded white silence?
Premiere should have NO trouble with standard MPEG2 streams.
