Results 1 to 21 of 21
    Oct 2008
    Indonesia
    created a couple of personal videos, intending to share them on the web, but I want to add a small watermark (jpg/png) to the corner of the video screen to offer credits to the people involved. How would that be done? Is it difficult? I am looking for the most simple and functional way, nothing fancy, what is the simplest solution to do that??
  2. Any NLE can do that. For super simple you can use Windows Movie Maker. Just search for 'How to make watermark in Windows Movie Maker' using google.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. Banned
    Oct 2014
    Northern California
    Most NLE's allow you to do that, during design or even at encoding time.
    The question I like to pose to you is why? Using watermarks this way is very unconventional and may actually annoy people. Giving credits in the movie and video industry is almost always done at the end of the video.
  4. Member DB83's Avatar
    Jul 2007
    Add to that you will have to re-encode your video when adding the watermark. So that will inevitably mean a loss of quality.
    Most watermarks are done for vanity purposes and add nothing. As my friend above states, if you want to add credits, add them as a still, or series of stills, at the end of the video and not as a integral part of the video itself.
  5. You can also add a branding watermark directly in YouTube that will not affect the actual video file.
    Oct 2008
    Indonesia
    i tried windows movie maker for adding watermark logo at the corner , it didn't work. Please stick to technical discussion.
    Apr 2003
    If you have done any editing to the videos perhaps you can tell us what you used. That way you may get specific instructions.
    Brainiac
  8. Banned
    Oct 2014
    Northern California
    Alright, let's get technical:
    Credits:
    Image of Dog CC-BY-2.0 - Ivan Mlinaric https://www.flickr.com/photos/eye1/3184963395/
    Button design CC0 by Newpball
  9. In the absence of any information, you could use aviutl.
    Logo on one track, photo(s)/video on another. Just reposition and resize.
  10. Or add the credits as subtitles, either for the video itself or after being uploaded to YouTube, so you don't have to further degrade the video by reencoding it.
    Oct 2008
    Indonesia
    what is re-encode? and is it a must to ''re-encode'' a video in order to add an embedded logo into the video? what is the fastest way of re-encoding or adding logo? nothing fancy, colored text is enough for my purpose. The videos I shot are mostly mp4 wmv or avi
    Dec 2005
    Finland
    Videos are compressed files. If you want to change the content (image) in any way, you need to decode, alter, and encode again. This is a time consuming process and it also slowly degrades the image quality, since with each encode details are essentially being thrown away.
  13. Excuse me jumping in here OP
    Is that true of http://www.aoaophoto.com/video-watermark-pro/
    Also if you add a jpeg in vegas to run all the way through would that mean a loss of quality? Thanks
  14. Originally Posted by Dopey2013 View Post
    You will lose quality with that cheap software, absolutely.
    In Vegas if you add the watermark to your original edited timeline -- not a re-imported output -- you will not lose any more quality than your normal encode. But I agree with the others it's not a good practice.
  15. Banned
    Oct 2014
    Northern California
    Adding a watermark always degrades the quality of your video!
    Oct 2008
    Indonesia
    $600????????????????????? I don't believe my eyes. Ridiculous price. I won't pay $600 to SONY
  17. Originally Posted by kenny1999 View Post
    What do you use as NLE?
    What do you mean "you will not lose any more quality than your normal encode. "? Thanks
  18. Originally Posted by Dopey2013 View Post
    Primarily Avid Media Composer and Premiere Pro. I bought Vegas Movie Studio because it handles stills better than Avid and IMHO is very well designed.
    Presumably you edited your videos on something. What was it? If you add the watermark before you export you only have the same generational loss as normal. If you export, re-import add a watermark and reexport -- that's a second encode.
  19. Originally Posted by smrpix View Post
    Primarily Avid Media Composer and Premiere Pro. I bought Vegas Movie Studio because it handles stills better than Avid and IMHO is well designed.
    Presumably you edited your videos on something. What was it? If you add the watermark before you export you only have the same generational as your normal export. If you export, add a watermark and reexport -- that's a second encode.
    The two quotes are mine and come up as kenny's. did i do something wrong?
  20. Originally Posted by Dopey2013 View Post
    Nope. I did. Fixed it in my post.
  21. Originally Posted by smrpix View Post
    ok thanks
