It's been a while since I used VirtualDub (1.9.11) in earnest so I'm rusty about specifying its settings. But after an hour or so of trial/error I can't get several files to play their audio content properly and I'd appreciate some help in discovering why please.
Here's an example:
https://www.dropbox.com/s/1p8np7obj29m587/TestStuttering.AVI?dl=0
(It's 31 MB; I'd have made it much shorter but I wasn't confident how to edit it without risking some other change that might muddy the water.)
P.S: I can successfully play that file (web source long-forgotten) in video players such as WMP, VLC and MPC-HC.
Terry, East Grinstead, UK
Results 1 to 9 of 9
If the playback problem is only within VD, maybe not a problem as long as the edited version plays properly in a regular software player. Editors like VD don't need to have smooth playback to function properly.
VirtualDub is an editor. It's not optimized as a media player. If your computer isn't fast enough to process the video in real time audio and video will stutter.
OK, thanks all, appreciate the quick replies. It must be a performance issue then.
I have my default filetype for AVI set to VirtualDub on this XP PC. These two or three files I hit on this morning are the first I can recall giving me that stuttering behaviour. I'll either switch to MPC-HC or remember this limitation when it happens again.
FWIW, VD File > File Information reports this:
https://dl.dropboxusercontent.com/u/4019461/VirtualDub-FileInfo-1.jpg
Isn't it strange that only the audio suffers?
Terry, East Grinstead, UKLast edited by terrypin; 12th Jan 2015 at 11:31.
