Hello All,
I just recently discovered that Verbatim DVD+R DL DataLifePlus *Made In Singapore* discs have been discontinued.
The reviews for the made in United Arab Emirates seem to be quite mixed leading me to believe that this brand is not as reliable as it once was.
What is being highly recommended now?
Results 1 to 25 of 25
No, not the AZO - these:
http://www.amazon.com/gp/product/B0024TNXNG/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 -
I went to order some on Amazon here and saw it listed as "Discontinued by Manufacturer"
So I went hunting on the actual Verbatim website and could not find them listed.
If you go here and roll your mouse over the picture, it shows Made in UAE
http://www.verbatim.com/prod/optical-media/professional-optical/dvd-r-dual-layer/dvd-r...ble-sku-96732/
Edit: Interesting, the photo for the 20 pack shows "Made in Singapore"
http://www.verbatim.com/prod/optical-media/professional-optical/dvd-r-dual-layer/dvd-r-dl-printable/
But when I clicked on the "Buy Now" link, I got "Sorry, this product is not available on our store at this time." -
http://www.rima.com/prod/1878.html
http://www.supermediastore.com/product/u/verbatim-96732-datalifeplus-double-layer-shin...-r-dl-media-50
These show to be made in Singapore, but best confirm that with them before ordering.
Edit: Also here: http://www.meritline.com/verbatim-8x-dvd-plus-r-dl-branded-on-spindle-96542---p-27286.aspx
These are the 8x variety. And if you absolutely have to have Singapore made discs, I'd call or chat with them online to make sure as one of the reviews says that they are using UAE made discs.Last edited by Kerry56; 11th Jan 2015 at 13:38.
AnonymousGuest
This place still advertises Singapore 8X Verbatim DL.
http://www.blankmedia.ca/shop/dual-layer-branded/dl-verbatim-8x-branded-30-pcs/ -
yes but those are the AZO discs (type I use) the original poster is talking about this kind- link below (which he provided in a link above to my reply), though I am unsure if there is truly much of a difference between the two and now wondering if this might also mean the AZO Singapore might be discontinued also
http://go.videohelp.com/?id=19619X769413&site=videohelp.com&xs=1&isjs=1&url=http%3A%2F...367584&xtz=300 -
I'm going to be blunt and direct.
1) When Verbatim moved most DVD+R DL production to India, we had the same arguments - "The made in India discs are 100% crap!" and so on. I did some personal testing and the Indian discs worked fine for me.
2) If you don't like Verbatim then you can buy Taiyo Yuden's VERY expensive and hard to find DVD-R DL discs. They don't make DVD+R DL discs.
3) That's it. If you don't like those choices then you can buy whatever you like and hope it works, but you'll have problems for sure.
I like their made in Singapore DataLifePlus discs too for DVD+R DL, but if they don't exist any more, I'm still going to buy Verbatim. -
I never had much luck with the Made in India discs. Problems for sure indeed. Glad that they work out for you though.
I like *some* Verbatims for regular things (the "Life series" - no way! Again - problems for sure indeed.) and I also like the TY DVD+R but for special things or as part of my backup routine, I liked the DataLifePlus (Made in Singapore).
Perhaps I should've specified that in my first post. -
jman98 is correct.
There was zero difference in media locations for Verbatim -- Singapore, Taiwan, India and UAE.
The anti-India info is unsubstantiated malarkey based on nothingness.Want my help? Ask here! (not via PM!)
Sorry for resurrecting this tread, but the early made in India Verbatim DL spindles I got were utter trash. 50% failure rate. Some even had obvious physical defects like bubbles.
Maybe they were eventually fixed but I never touched them after that. -
May have been just a bad case. I have used them before (a few years back) when Best Buy was selling them and before they started getting the Singapore back in again. Did not have any burn/read issues with the India discs, though (and this goes for where ever they were made) a couple out of the cakebox always looked sketchy and they would hit my trash can before my computer, except in the India case where upon visual inspection I ended up throwing away say 10-15 out of 50. But for what I did end up using to burn, never had a problem with them
Currently have been using the MKM003 from the United Arab Emirates and so far no issues with them burning or reading either -
Well, I'm going to find out with the UAE shortly as I'm on my last stack of Singapores. I haven't had a bad burn on the Singapore disks for years now, so the UAE has a high standard to live up to.
I'm with you. My last batch of Singapore was used up a few months back. The particular ebay seller where I was buying them en mass no longer had any Singapore left but did have the UAE MKM003. It is also nice because they list where they are made as well as the media code in their description so you know what you are getting
you will get the usual "I don't like the look of this disc" but say out of 25 it was like 3 tops. Also as previously mentioned so far no miss burns or read errors with them. For more important data I would have imgburn do a verify check and that too- no issues
I have been using them less than a year (ehh just about a year) but so far if I can no longer get Singapore made, I will gladly take these over some of the others -
I've had no complaints with the UAE discs.
As time has progressed, I do burn less and less of those. Everything has shifted to drives or BD media now.
Noting that BD media is a terrible way to archive.Want my help? Ask here! (not via PM!)
Oh? How so? So far, I've only used one BD -R to back up some files and would like to know before I do anymore.
(I bought these:
http://www.amazon.com/gp/product/B005RY6JCC?colid=2YGC2AI7J93B5&coliid=I3KRTXHR8T3NTP&...dp_o_pd_nS_ttl )
I prefer to use the burn to disc plus store on external hard drive archival method. -
There's nothing wrong with using Blu-ray as one part of your backup strategy. I wouldn't rely on them alone, or for that matter, any one type of data storage for really important, irreplaceable material.
Those Panasonic discs should be very good, some of the best available in fact.
I've been following Blu-ray media since it first came out, and my burns from 2008 are still doing well. The only discs I've had fail were made by Ritek, and I do not recommend them for any purpose. The Ritek discs tested good, and were readable for three to four years before deteriorating to the point they could not be read or copied.
FTI/Falcon and Verbatim are what I've been using, and all still work perfectly well. -
The construction of BD is inverse CD with a thin plastic coating.
The top of a CD is fragile, and the bottom of BD is fragile. That's why.
DVD is a sandwich, and it the only archival optical format.Want my help? Ask here! (not via PM!)
That's a specious argument. With proper storage and handling, there is nothing inherently inferior with CD's and Blu-ray. I recently went through some old discs, and threw out some old CD's. They were TY discs burned sometime between 1999 and 2001. Still perfectly readable.
This is not to say that recordable optical formats are permanent solutions for long term storage. If your aim is preservation of data for posterity, then optical discs are not a good choice. I wouldn't trust them for anything that needs to be kept for, say, fifty years or more, simply because the dye layer will eventually deteriorate. -
Thank you for your input, Kerry. I agree with what you said about not relying on just one type of data storage for archiving irreplaceable material.
I knew from past experiences and research that Ritek etc. CDRs + DVDRs were pretty much crap quality discs and I suspected that their BDRs were most likely the same. I'm *just* beginning to use BDrs for back up so
thank you for the verification on the quality of the Panasonic BDRs!
It's also good to know that there are other brands of quality BDr discs available as well. (I haven't tried Falcon yet...)
Well now, that's interesting. I didn't know that about the BDRs.
When I want to destroy CDRs before disposal, all I have to do is scratch the top and the surface flakes off into little shiny pieces. So you're saying that it is the same for the bottom of BDRs?
I have many CDRs that were burned several years ago and they are still readable however for space saving and updating purposes, when DVDrs became available I started to back up the contents of my data CDRs to those. Now days, I have an HD camcorder and was looking to use the BDRs as part of my backup strategy.
*Edit: I have read some where (can't remember where now) - some people say that using dual layer discs (both DVDR and BDR) for back up is bad but I don't remember if they ever said why or if they did, I don't remember that either
No.
Proper handling of media is only a small part of longevity.
I have CD-R much older than yours, from at least 1995, and most of mine are fine too. However, than alone is not proof of media longevity. Here's why:
CD has the entire upper layer exposed to the elements. Case closed. Lifespan mostly depends on the added protection it was given, if any. If the disc has 100% of the upper layer sealed, then it should be fine.
(And those discs of mine from 1995? Not all of them have survived. Any disc that had an exposed upper tends to have pit marks. Only discs that were completely covered by branding or quality inkjet surface survived.And those discs of mine from 1995? Not all of them have survived. Any disc that had an exposed upper tends to have pit marks. Only discs that were completely covered by branding or quality inkjet surface survived.)
Sony knew about Blu-ray defects. TDK saw it the earliest, from what I've read. Discs never spin at a pure flat horizon, and there is minor wobble. The disc will, at some point, impact surfaces. That why even the most careful handling doesn't 100% prevent scratches, including microscratches that cannot be seen by the naked eye. Because of the inverse construction, combined with thinner data grooves, even the smallest microscratch can ruin the disc. Manufacturer created scratch resistance on Blu-ray, similar to more expensive DVDs. All BD has this, for this reason. However, ever scratch resistance is not 100%. Some manufacturers have crap for protection, and some cheap Chinese knockoff junk has none.
Read more: https://en.wikipedia.org/wiki/Durabis
DVD is a 50/50 sandwich. That's why it's archival, and the others are not. And even then, only SL is archival, not DL, due to the light remission to the second layer.Last edited by lordsmurf; 12th Dec 2015 at 09:19.
