  1. Hello member,
    I am new here.
    I want capture few videos. timing of video is 120 to 150 hours.
    i tried few screen capture software like reply video capture.
    when make full screen view and try to record video it give error window is not selected.
    i want to record in less size. like 20gb is it possible.
    video should be clear means if something written in video than i can read it clear.
    what should i do.
    can any one guide me.
  2. I probably am misunderstanding you but your post implies that you want to record 150 hours of video and compress it into 20gb.
    You can't do that.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. Sorry mine english is not good.
    M just asking is it possible.
    want suggest me software for screen recording.
    can tell me aprrox size of 120 to 150 hours recording..
    i dnt want hd. I want 360p or 480p.
  4. Member DB83's Avatar
    Jul 2007
    I think you mean minutes. 120 = 2 hours
    Replay usually captures screen in wmv or mpeg2. A 120 MINUTE video in maximum mpeg2 will be 8 gb. Wmv will be smaller but I do not think you can capture that in full-screen.
    If these videos are web transissions it is easier, if possible, to directly capture the stream rather than the screen. Of course, if the stream is protected then you have no choice.
  5. Originally Posted by rahulcrazy View Post
    It's whatever size you want, depending on the bitrate you use. The quality you get will depend on the frame size, frame rate, how much the video changes from frame to frame, the codec you use, etc.
  6. Ok.
    thankz.
    how can capture full screen view.
    liitle bit setting guide in recording video.
