    May 2013
    here and there
    Hi guys
    can anyone help me is there any chance to capture LG TV screen, for example through HDMI cable or something like that? I have this type of LG TV, and i know that there is a recording function on this tv, but i want to record something from my smart tv apps, are there ANY chance to do this? can i somehow connect my tv to pc to do this??
    thanx for any help
    I doubt that as most tvs has no video output.
    But can't you find any similar apps on your pc?
    Feb 2004
    Australia
    Only via a smart tv box and hdmi capture device as pass through.
    Very few late model tv's have video outputs, becoming rare.
    May 2013
    here and there
    oh crap
    so, the only chance to record something is to take a camera or mobile phone?
    Aug 2006
    Originally Posted by kasda View Post
    oh crap
    Yes, if your TV is the only device that allows you to view the content that you want to record. The TV's recording function won't work for recording anything other than the output from its tuner. It looks like the TV doesn't have an outgoing video connection that you could record from either.
    As already suggested, if you can use an app on a PC, or on another device with HDMI out to watch the same content, the content could be recorded.
  6. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Maybe there is a little chance, if your TV has a USB port and if your remote control have a rec button.
    When a USB key or external hard drive is plugged with some TV and when you pushing the rec button, what happens on TV is recording in .mp4 or .avi on the usb key and to stop the capture you press the "stop" button.
    Later, you check what is in the usb key with your computer, to see if it record properly.
