I just recently decided that I've wanted to record let's plays for youtube. I have dxtory software, which I use to record it. I record the videos and then I watch them in media player, and everything is working fine (The video is good, the game sound and good, and my voice is good) then, I put the videos into an editing software (movie maker, I tried them in a different one also. I don't remeber the other one I tried.) Everytime, with every editor I try, when I put them into the editor and watch the video, the voice is gone. Everything else is the same, just my voice isn't there. I tried extracting the audio, but it just extracted the game sound and those files were missing my voice. Basically, I need to be able to edit my videos and have my voice be present. Can anyone PLEASE help me with this? It's been happening for a few days and I'm very frustrated. I hope it's an easy fix![]()
First guess is that you have several audio channels and your editor didn't select all of them. Use MediaInfo and post the info here from the 'tree' view. If you do have multiple audio channels, you might have to down mix them to stereo or mono before editing or use a different editor. Maybe AVIDemux.
General
Complete name : C:\Games\Videos\OpenDoor SMP S1E1 Part 1.avi
Format : AVI
Format profile : OpenDML
File size : 2.77 GiB
Duration : 1mn 20s
Overall bit rate : 296 Mbps
Original source form/Distributed by : Video:YUV420|CompressV3 Audio0:Speakers (Realtek High Definition Audio) Audio1:Microphone (Realtek High Definition Audio)
Writing application : DxtoryCore ver2.0.0.124
Video
Format : xtor
Codec ID : xtor
Duration : 1mn 19s
Bit rate : 280 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 fps
Bits/(Pixel*Frame) : 2.254
Stream size : 2.60 GiB (94%)
Audio #1
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 1mn 20s
Bit rate mode : Constant
Bit rate : 9 216 Kbps
Channel(s) : 2 channels
Sampling rate : 192 KHz
Bit depth : 24 bits
Stream size : 88.2 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 983 ms (58.99 video frames)
Audio #2
Format : PCM
Codec ID : 1
Duration : 1mn 20s
Bit depth : 24 bits
Interleave, duration : 983 ms (58.99 video frames) -
Open the AVI file with Audacity with FFMPEG & LAME libaries installed.
Use "Tracks -> Stereo Tracks to Mono" for each track.
Use "Arrow down (left side) -> Make Stereo Track"
"File -> Export -> MP3"
Drag-drop the AVI file on YAMB
Deselect audio tracks
Drag-drop the MP3 file from Audacity onto YAMB and press Next.
Use the created MP4 file in Movie Maker.
