    Feb 2008
    I was thinking about purchasing the Diamond ATI Theater HD 750 USB TV Tuner to capture ATSC OTA MPEG-2 streams. I have a couple of questions if anyone has this USB device or knows of this USB device.
    Since it is USB, does it allow capture of the raw MPEG-2 stream or does it reencode the stream?
    Does it retain the closed captions in the captured transport stream?
    Thanks.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What?
    Aug 2006
    Thanks.
    The HDHomerun Extend (also called the HDHomerun Plus) is the only ATSC PC TV tuner I have seen that can re-encode the MPEG-2 transport stream (to H.264). All other ATSC TV Tuner devices that I am aware of, including the ATI Theater HD 750 USB TV Tuner, deliver the tuned sub-channel's transport stream as is.
    Since the ATI Theater HD 750 USB TV Tuner captures the transport stream as is, yes, it retains the closed captions. (They are in the GOP user data.)
    Last edited by usually_quiet; 10th Jan 2015 at 16:41. Reason: Fix bad cut-and-paste
