Results 1 to 20 of 20
    Nov 2006
    Hello,
    Wasn't sure if this is a video problem, but I am trying to store some dvd's as .ISO files on my flash drive.
    I have a 128gb usb 3.0 flash drive that's got 54gb Used Space and 64gb Free Space. I've dragged a few files that are a little over 4gb and I get a message that says "the file is too large for the destination file system"...as if there's not enough room on the drive for those size files. I was able to drag a bunch of 3gb files with no problem. Anyone know of any reason why a 4 gig would cause any trouble vs anything >4gig? It shouldn't matter how big the size is as long as it's less than 64 gig correct?
    Please help,
    Jason
    canada
    Your flash drive is formatted at fat32 which has a 4 gb limitation,it needs to be formatted to ntfs to overcome that limitation.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Incorrect!!
    Format the drive to NTFS instead of FAT32.
    Only NTFS can support single files larger than 4gb.
    Mar 2006
    Wrong-exFAT can also store >4GB files if you are on Win7 or newer.
    Nov 2006
    Ya my flash drive is set up as FAT32. I do have Windows 7 64 bit.
    Are you saying if I have to reformat to NTFS, I'll lose all of the files currently on there?
  6. Banned
    Oct 2014
    Northern California
    What is the issue?
    Just copy the files onto a hard drive, reformat the drive and then copy it back.
  7. Banned
    Jun 2004
    Oh for F*CKs sake!!!!!!!!
    Let me count the ways!!!!!!!
    Hopefully it is not for watching videos on a standalone player as none of my Blu-ray players will recognize exFAT formatted drives.
    But it is such a common standard!!!
  8. Banned
    Oct 2014
    Northern California
    Actually in some cases exFAT is not a bad choice at all!
    Nov 2006
    What is the issue?
    Lol, ya ya I was afraid I'd have to do that. Ok. Thanks, that's what I'll do.
    Thanks for the reply's everyone
  10. Banned
    Jun 2004
    I know there is a way to convert/format hard drives from fat32 to NTFS without losing anything on the hard drive but I have never tried with a USB thumb drive before so I don't know if it would work but it might......
  11. Banned
    Oct 2014
    Northern California
    I would not take any risk, copying 50 something GB over USB 3.0 should not take very long and if you want to be super careful you can do a copy with verification.
  12. Banned
    Jun 2004
    I didn't say to do it blind!!!
    I have done it may times on internal hard drives so I know it works and there is an old as hell thread somewhere here where I posted how to do it with photos and I am sure you could google it and find it also.
    But I would imagine it would work for anything external also, but I would back everything up first before trying it just to make sure.
    It has been a long time since I have done it as I have always formatted everything to NTFS for many years now.
  13. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Just an aside.......I knew you could do the reverse Macrorit NTFS To FAT32 Converter - portable but didn't know one could do a FAT32 to NTFS. Interesting. I'm about to convert as NTFS drive to FAT32 for my A/V receiver with all my CD's on it.
  14. Member Cornucopia's Avatar
    It's probably obvious, but...
    Before you do, netmask, back up to a separate NTFS partition and double-check that none of the files being migrated are >4GB.
    IIRC, non-destructive FAT32->NTFS migration has been around (and built into the OS) since ~Win2k.
  15. Originally Posted by qz3fwd View Post
    ext3 also and many other filesystems too...
    http://www.ext2fsd.com/
    I assume that market penetration is higher for ext3 than for ex-FAT (as around 75% mmedia devices use as embedded OS Linux)
  16. DECEASED
    Jun 2009
    Heaven
    Wrong --- exFAT is exFAT, even on Windows XP
  17. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Thanks for that info - just has never been on my radar. I actually have 2 backups! The thought of feeding all those CD's into my PC sent shudders through me as I did it. One backup plus scans of all my family important documents and photos are nicely sitting in my best friends safe.... never have enough backups....
  18. Member
    Mar 2006
    Well, the OP did say that they are on Win 7, so your XP point is mis-placed. Windows to my knowledge does not natively support exFAT anyway.
    Furthermore the OP did not state what he was using it for-and the vast majority of the use would likely be on a Windows machine so the other posters comment about linux is a big fail since NO Windows version supports linux native filesystems and never will, so that is not a really viable option for the OP. Regardless, the Windows, OSX, and Linux devices I use are all able to read/write exFAT which DOES allow 4GB file sizes so it is a working cross system filesystem.
  19. Originally Posted by qz3fwd View Post
    Linux file support is easily available for Windows and it cost null - no money - so it is purely user choice.
  20. DECEASED
    Jun 2009
    Heaven
    Then your remark about "Windows 7 or higher" is redundant and unnecessary
    Also, you'd better improve the contents of your knowledgebase:
    { http://en.wikipedia.org/wiki/ExFAT }
    AND/OR your text interpretation skills as well
    Last but not least, be welcome to my Ignore List.
