1.) Can DVD-R, DVD-RW, DVD+RW be formatted to VCD standards?
2.) Can you achive smaller file size by encoding with VCD-PAL standards? I can play both NTSC and PAL.
3.) What does PAL stand for? I know NTSC
1.) People have reported that it is possible with SVCD feed on a DVD-R, - so hearing that, I would say yes to VCD. Maybe DVD Demystified can help you there http://www.dvddemystified.com
2.)As file size is determined more by the bitrate, I doubt there would be a significant difference.
3.)PAL, stands Phase Alternate Lines. -
I dislike questions when one is asked "what is better" when it comes to subjective judging. Normally I would say, if you're in an NTSC country use NTSC (also when encoding) when ni a PAL country use PAL.
If you are interested in what the pros and cons of each TV system are, visit this site http://www.ee.surrey.ac.uk/Contrib/WorldTV/compare.html
which I am sure will help you to decide!
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 3rd Dec 2007, 23:10 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
