All, quick question about encoding to MPEG2 for SVCD with tmpgenc: If you set the rate control mode to CQ, and the bitrate to max at 2520, would that not be as high, if not higher quality then any other setting? Would that be the same as doing CBR at 2520? The file sizes would be larger then the VBR modes, but wouldn't quality be as good as VBR, if not better... inlcuding motion etc?
Thanks in advance!
Jeff
The general consensus (that I've read) seems to go against this, but I don't get it either. I'm having considerably better quality results using CQ than VBR (given roughtly the same resulting file size)...
Then again I'm an utter n00b at this... -
Wierd. I too get better recordings using CQ, then using VBR. I just tested CBR with a maxed bit rate, and it looked better then CQ even. Sigh, this is so confusing!!! I wish there was more documentation out there on this.
Jeff -
Originally Posted by djnibler
http://tangentsoft.net/video/mpeg/enc-modes.html
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Thanks for the great link Kwag!! Great reading. This confirms what I found in my tests, that CBR ends up being better then VBR more often then not.
That leaves one question: With CBR and tmpgenc, the highest bitrate available is 2520. Would this not mean that even the best CQ converted mpg could not look any better then the same clip converted in CBR at 2520 (the max)? The difference would probably be that the CQ mpg is smaller though... but the quality of the CBR must be the same, if not better correct?
Jeff -
For me, CBR is a waste of bandwidht/resources, as it just keeps a constant stream of data without any quantization analysis.
On the other hand, CQ analyzes the frames to try an maintain a quality, and vary the bitrate acordingly.
That's why I am using CQ all the time. And the conclusion of the article above seems to point in the same direction too.
So in theory, if you have your encoder set to CBR 2,520Kbps, it should give you the same quality of CQ=100 at the same bit rate.
But your CQ encoded file size will be lower.
Sounds good. All I'm doing for now is recording my favorite half hour show to SVCD. Obviously at 30 minutes, I can go big on the filesize. The encoding time seems similar to me though. If I ever try a whole movie, I'll definately go the CBR route.
With Tempgenc, changing the movement quality checking to highest makes a HUGE difference from what I can tell... though just stepping it down 1 notch cuts the encode time in half.
Thanks again!
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 02:09 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 16:21 -
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 20:08 -
Help setting quality settings on mencoder converting videos on my website!
By funnyspo in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2009, 16:55 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
