    Mar 2011
    Oregon, US
    Is there a video splitter that i can split at different time intervals such as (5m,5m30sec) and save the subsequent files f4om the cuts? John
    Mar 2011
    Oregon, US
    Preferably for free.
  3. Member Cornucopia's Avatar
    Yes.
    Mar 2011
    Oregon, US
    Now, which one do u recommend?
  5. Member Cornucopia's Avatar
    Virtualdub, AVIDemux, AVIUtil. AVISynth, ffmpeg - depending upon how complicated you need. Others may be necessary or preferred, depending upon input container format.
    Mar 2011
    Oregon, US
    Mkv is the input container
    Preferably easier the better
    A set and forget type of program set it for five minutes and save each.
    Jul 2012
    FrogLand
    Hi RBCC
    As Scott says, there are many free tools, depending upon the task needed.
    Video splitting is always tricky, and usually, best results are not obtained with "easy one click software"
    But :
    as it seems you're loooking for the simplest solution, maybe you should try FreeVideoEditor (ex-FreeVideoDub) which could help you achieve your multiple splits goals.
    If you're not succeeding, you could try a ffmpeg batch file, but that requires some CLI knowledge, so we"ll get back to that later if needed.
    Good Luck
