Results 1 to 17 of 17
  1. Guys i've got a problem with AviSynth or MeGUI personally, look at this pic shows the problem
    Which version do i have to use?
  2. Member DB83's Avatar
    Jul 2007
    Copy/paste your script here.
    We may be able to assist then.
  3. This is the script:
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86 \MeGUI_2418_x86\tools\avisynth_plugin\ffms2.dll")
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86 \MeGUI_2418_x86\tools\avisynth_plugin\RemoveGrain. dll")
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86 \MeGUI_2418_x86\tools\avisynth_plugin\Repair.dll")
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86 \MeGUI_2418_x86\tools\avisynth_plugin\SmoothD.dll" )
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86 \MeGUI_2418_x86\tools\avisynth_plugin\FFT3DFilter. dll")
    DirectShowSource("C:\Users\YasTon\Desktop\Encoded\ ep01.ts", fps=25.000, audio=false, convertfps=true).AssumeFPS(25,1)
    #deinterlace
    #crop
    LanczosResize(720,405) # Lanczos (Sharp)
    #denoise
    Tweak(hue=2,sat=1.3,bright=1.2,cont=1)
    ConvertToYV12()
  4. Originally Posted by yaston View Post
    This is the script:
    #deinterlace
    #crop
    #denoise
    ConvertToYV12()
    Is there a space at the beginning of the filename ? Or is that the message board or my broswer playing tricks?
    or
    "C:\Users\YasTon\Desktop\Encoded\ep01.ts"
    Open the avs file in something like vdub, is there an error message ? If so, post it verbatim
  5. No, there's no space... and by the way this script "ConvertToYV12()" in the end i didn't put, it has been done automatically !!!
  6. Anonymous
    Guest
    Apparently megui produces a log. Check if it contains any meaningful error message.
  7. Member DB83's Avatar
    Jul 2007
    Well I see a space as well.
    And in my limited knowledge of avisynth, is ").AssumeFPS(25,1)" valid code ? ie AFTER the ')' of the source video ?
    Wouldn't that be better on its own line ?
  8. Anonymous
    Guest
    Avisynth would throw a "LoadPlugin" error if it encountered something like this. Of course, if megui does not handle that error, the user will be left guessing.
    The line is perfectly valid.
    May 2014
    Memphis TN, US
    This line is post #3 is an error:
    LoadPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86\MeGUI_2418_x86\tools\avisynth_plugin\ffms2.dll")
    It should be:
    LoadCPlugin("C:\Users\YasTon\Desktop\MeGUI_2418_x86\MeGUI_2418_x86\tools\avisynth_plugin\ffms2.dll")
    Why are you loading ffms2 if you're using DirectShowSource?
    - My sister Ann's brother
  10. Anonymous
    Guest
    It should be:
    How do you know that he's loading the C-plugin?
    I suppose that's the script megui creates and he probably does not have the knowledge to modify it.
  11. Originally Posted by yaston View Post
    I can see an odd height for resize, should be even. MeGui does not report type of avisynth returned error?
    Drop that script into VirtualDub or MPC-HC, it should be more specific.
  12. Anonymous
    Guest
    Well spotted, that's probably the culprit. As for megui's error handling - I better won't comment or I might get banned forever from this forum.
    May 2014
    Memphis TN, US
    How do you know he isn't?
  14. I understood nothing, i don't have knowledge about it just simple ways... thank you guys ^^
    Actually i need some to handle it by TeamViewer if you want to...
  15. Anonymous
    Guest
    I don't - which is the point.
  16. Member DB83's Avatar
    Jul 2007
    Now I might sound hard but if you do not understand then you should not be attempting to use tools that have a steep learning curve. Yeah. Most of avisynth, as you might have gathered, goes over my head.
    Try more basic tools such as avidemux or handbrake.
    May 2014
    Memphis TN, US
    Whatever, whether or not MeGUI puts the line there is up for debate, I just don't use most of the free apps if there is serious mod to be done on a source, so I can't say. There are different editions of ffms2 and Avisynth, and the setup I've been using requires LoadCPlugin.
    In any case IMO the O.P. is apparently trying to do stuff that requires Avisynth. Anyway we have no original sample that I've seen anywhere, so a lot of guessing will result from that.
