Are these non-MPEG1 audio stream header seen errors or are they normal?????
ThanxCode:generated image (337880 sectors [75:05.05]) may not fit on 74min CDRs (333000 sectors) OGT streams available: 0 0 0 0 OGT streams available: 0 0 0 0 writing track 1 (ISO9660)... 'update scan offsets' option enabled for the following tracks! writing track 2, MPEG2, NTSC 2/3 D-1 (480x480/30fps), audio[0]: l2/44.1kHz/64kbps/stereo ... strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc) MPEG packet statistics: 1334 video, 57 audio, 0 zero, 0 ogt, 0 unknown writing track 3, MPEG2, NTSC 2/3 D-1 (480x480/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ... strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc) non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen mpeg: some marker is not set... non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen mpeg: some marker is not set... non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen non-MPEG1 audio stream header seen MPEG packet statistics: 303442 video, 32297 audio, 0 zero, 0 ogt, 0 unknown writting post-gap ('leadout pregap')... finished ok, image created with 337880 sectors [75:05.05]
No, this isn't something regular, how did you do your MPEG file source ? did you do some multiplexing with a strange audio source settings ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Ripped DVD w/ Smart ripper then ripped audio from vob's w/ Graphedit.(http://www.doom9.org/graphedit_wav.htm)
You think this is the cause?. When I use DVD2AVI to do the audio sometimes the audio plays lightly.
You can use a program like Cool Edit or even TMPGEnc itself to boost up the Volume of the WAV file created by DVD2AVI if it's too soft.
I'm not familiar with GraphEdit so I can't tell you from experience that it's the problem, you should check the WAV file that was created (was it a WAV?) and see if it uses any codecs in it (like AC3 codec or MP3).Email me for faster replies!
Best Regards,
Sefy Levy,
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 00:36 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
