What software will allow me to convert a DVD file (VIDEO_TS) fromat as a single VOB file.....The TS folder has around 10 vob files, so I can either merge them or just extract as a single one, either way whats the best tool to use.![]()
You may be able to set up your ripper (or PGCDemux) not to split and not to demultiplex, but to extract the streams of the main movie PGC into a continuous PGC VOB file. For whatever reason. If you are interested in archiving, rather store an ISO (or MDS) image of the whole DVD.
DVDFab 8 or older (I don't recommend version 9) will open Video_TS folder and under conversion settings, VOB > VOB Passthrough > Splitting > None. This will give you a single VOB/MPEG of the movie on the DVD.
IMO, this is the only way you would want to rip a DVD. For Episode or Music DVDs > VOB > Vob Passthrough > Splitting > Split By Chapter.
If I'm not mistaken, You can do the same with DVD Decrypter. It won't work on newer DVDs but should work on Video_TS folders that you've already decrypted.
