I'm following 'Sefy's Classical Newbie DVD Conversion Guide v2.03', all is working great apart from one thing. TMPGenc will not split the resulting MPEG into chunkls suitable for an 80min CD-R - I just get one big chunk. I don't even have the ability to select the percentage of media in step 5/5 of the wizard. I am using the evaluation copy.
Any help would be greatly appreciated.
David
(Complete novice)
under file->mpeg tools...there should be cutting/joining tools u can use to split the file
In Tmpgenc, go to mpg tools, and select Merge/cut. You can cut your file there.
If you followed the guide correctly, then in the TMPGEnc from Step 3 it explains how to use the Source Range to encode your movie in two parts.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
USB DVD player - scenes with water and some audio struggles to play......
By Cieran in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st Nov 2011, 19:05 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
(Newbie) Adding subtitles with TMPGEnc 3
By mrwednesday in forum SubtitleReplies: 0Last Post: 2nd Mar 2010, 19:00 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:03
