  1. Is there a tutorial which explains the files that i need to DL & how to execute the process. I'm by no means a computer novice, from what i've read the process seems quite complicated though.
  2. Hi ,
    The process below is :
    _ free
    _ without needing JAVA etc.
    _ PORTABLE
    _ under Win XP <= my use
    Keep in mind : 'PHP' needs sometimes other DLL and 'php.ini' has to be modified to run .
    1st step : INSTALLING
    Download 'php' at :
    http://www.mediafire.com/download/85a2dvag8a7o6io/php.rar
    EXTRACTING
    Right click on 'php.rar' ; 'Extract to' ;
    In 'Select to' write : 'C:\php' , and ok .
    in "c:\php" create a batch file ( Upd.bat ) ( see below ) , for updating AdobeHDS.php
    @echo on
    php AdobeHDS.php --update
    pause
    :end
    Open Firefox
    Paste the link : https://addons.mozilla.org/en-US/firefox/addon/hds-link-detector/
    Click on the button "Add to Firefox" , for installing .
    After , an icon "HDS Link Detector" will appear in the right-upper corner
    2nd step : RUNNING
    _ Open Firefox
    _ Click on the icon "HDS Link Detector" to enable it
    _ Paste the link of your video and run it
    _ At the beginning for the video , a small dialog box , will appear (on the right) over the task-bar . Click on it !!!
    _ Stop the video
    _ Open a text editor , paste the text got just previously .
    (example : php ... Firefox/34.0" )
    _ finalize your batch file , to be saved in "c:\php" !!! Example 'Z_Hello.bat'
    @echo on
    pause
    :fin
    Launch your batch file 'Z_Hello.bat' .
    Wait until the DL is finished .
    Regards .
    === Help ===
    You can compare and see script with following switches for AdobeHDS:
    --help displays this help
    --debug show debug output
    --delete delete fragments after processing
    --fproxy force proxy for downloading of fragments
    --play dump stream to stdout for piping to media player
    --rename rename fragments sequentially before processing
    --update update the script to current git version
    --auth [param] authentication string for fragment requests
    --duration [param] stop recording after specified number of seconds
    --filesize [param] split output file in chunks of specified size (MB)
    --fragments [param] base filename for fragments
    --fixwindow [param] timestamp gap between frames to consider as timeshift
    --manifest [param] manifest file for downloading of fragments
    --maxspeed [param] maximum bandwidth consumption (KB) for fragment downloading
    --outdir [param] destination folder for output file
    --outfile [param] filename to use for output file
    --parallel [param] number of fragments to download simultaneously
    --proxy [param] proxy for downloading of manifest
    --quality [param] selected quality level (low|medium|high) or exact bitrate
    --referrer [param] Referer to use for emulation of browser requests
    --start [param] start from specified fragment
    --useragent [param] User-Agent to use for emulation of browser requests
    more info: https://github.com/K-S-V/Scripts/wiki
    Example :
    C:\PHP>php AdobeHDS.php --manifest "http://ynethd-f.akamaihd.net/z/upl/612/401.flv/manifest.f4m?g=OHKICXARBTSG&hdcore=3.0.3" --delete --auth "als=0,3,
    NaN,0,0,NaN,0,0,0,25,f,0,2517.53,f,u,OHKICXARBTSG,3.0.3,25&hdcore=3.0.3" --quality high --useragent "Mozilla/5.0 (Windows NT 5.1; rv:33.0) Gecko/20100
    101 Firefox/33.0" --outfile HotYnet_video.flv
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
     Available: 593
     Selected : 593
    Fragments Total: 503, First: 1, Start: 1, Parallel: 8
    Downloading 503/503 fragments
    Found 503 fragments
    Finished
  3. The process below is :
    _ free
    _ PORTABLE
    Are these instructions for XP? I'm using Windows 7. Are the processes the same?
  4. Hi ,
    You have to try .
    Create and install all things in D:\php .
    It is "portable" . If it don't work you can delete without problem .
    Cheers .
