  1. Hi. when i add a m2ts file (From Blu-ray Disk) to Ripbot, during importing, this error apears:
    mediainof of 00000.mts file:
    General
    Complete name                            : C:\BDMV\STREAM\00000.m2ts
    Format                                   : BDAV
    Format/Info                              : Blu-ray Video
    File size                                : 10.2 GiB
    Duration                                 : 48mn 13s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 30.2 Mbps
    Maximum Overall bit rate                 : 48.0 Mbps
    Video
    Menu ID                                  : 1 (0x1)
    Format                                   : VC-1
    Format profile                           : Advanced@L3
    Codec ID                                 : 234
    Duration                                 : 48mn 13s
    Bit rate                                 : 27.1 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 25.000 fps
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.522
    Stream size                              : 9.12 GiB (90%)
    Audio #1
    Menu ID                                  : 1 (0x1)
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : 129
    Duration                                 : 48mn 13s
    Bit rate mode                            : Constant
    Bit rate                                 : 640 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Stream size                              : 221 MiB (2%)
    Audio #2
    Menu ID                                  : 1 (0x1)
    Format                                   : AC-3
    Codec ID                                 : 129
    Duration                                 : 48mn 13s
    Bit rate                                 : 640 Kbps
    Bit depth                                : 16 bits
    Audio #3
    Menu ID                                  : 1 (0x1)
    Format                                   : AC-3
    Codec ID                                 : 129
    Duration                                 : 48mn 13s
    Bit rate                                 : 640 Kbps
    Bit depth                                : 16 bits
    Text #1
    Menu ID                                  : 1 (0x1)
    Format                                   : PGS
    Codec ID                                 : 144
    Text #2
    Menu ID                                  : 1 (0x1)
    Format                                   : PGS
    Codec ID                                 : 144
    How i can solve this problem ?
  2. DECEASED
    Jun 2009
    Heaven
    Can't you configure RipBot for NOT using DirectShowSource
    Notice, I'm assuming the Avisynth script above was generated by RipBot itself, since I don't use RipBot
    FWIW, there are two better alternatives to DirectShowSource, namely FFVideoSource (from the FFMS2 plugin) and DSS2Mod (which does not require Haali Media Splitter).
    P.S.: As a last resort, you (still ) can send a private message directly to Atak Snajpera at Doom9's forum
    http://forum.doom9.org/member.php?u=99881
    // apparently he does not visit Videohelp anymore : -/
  3. thanks, I sent pm to Atak Snajpera and problem was solved by his guidance!
    Dec 2014
    San Jose, CA
    I've never even heard of RipBot. However, have you ever considered using another freeware? Handbreak is a solid program and has never given any grief when using m2ts. Overall it's easy to use and one you get the right advanced settings through trial/error and a bit of research, it gives you really nice looking encodes.
    A Handbreak project I was proud of, was the encoding work I did on Breaking Bad. 1080p source was 230gb's for the whole show averaging 3gb's or more per episode. Encoded to 720p averaging 600-700mb's per episode and it looks AMAZING. Just under 40 gb's for the whole set.
  5. It does not matter if you use ripbot or handbrake or megui. All guis use the same encoders anyway (x264 and x265).
