  1. First of all, sorry, I don't know much about this ripping stuff
    I use MakeMKV to convert iso and/or BDMV folders to .mkv to watch them on TV. Have done quite a few rips, and most of the time it worked flawlessly. But now I found 1 movie and I can't understand whats wrong. I know it's probably TV's fault but I want to know why some mkv's work and some don't. TV - Panasonic TX-42ASE650
    ALSO the original m2ts file plays fine, but it has dtshd audio, and my hometheater plays only DTS and makemkv did exactly what I needed when the file worked. Any other solutions how to deal with this?
    This works
    General
    Unique ID                                : 156952967372225385876604060656374591023 (0x76140ABEB1ACC2D78A2C336F67CF2E2F)
    Complete name                            : H:\Shared\*****.mkv
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 28.1 GiB
    Duration                                 : 1h 41mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 39.5 Mbps
    Movie name                               : *****
    Encoded date                             : UTC 2014-12-30 13:57:20
    Writing application                      : MakeMKV v1.7.8 win(x64-release)
    Writing library                          : libmakemkv v1.7.8 (1.2.0/1.1.0) win(x64-release)
    Video
    Format profile                           : Stereo High@L4.1 / High@L4.1
    MultiView_Count                          : 2
    Format settings, ReFrames                : 3 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 41mn
    Bit rate mode                            : Variable
    Bit rate                                 : 36.8 Mbps
    Maximum bit rate                         : 29.8 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.740
    Stream size                              : 26.2 GiB (93%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Aand, this doesn't Thats what I get playing some mkv's (I get these from other releases)
    General
    Unique ID                                : 117485428996463486833418320488912631011 (0x5862DEDDE515E810A0770F1ECF0BB4E3)
    Format                                   : Matroska
    File size                                : 20.6 GiB
    Duration                                 : 1h 51mn
    Overall bit rate                         : 26.4 Mbps
    Movie name                               : *******
    Encoded date                             : UTC 2014-12-30 17:55:05
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 2 frames
    Format settings, GOP                     : M=1, N=10
    Duration                                 : 1h 51mn
    Bit rate                                 : 24.4 Mbps
    Bits/(Pixel*Frame)                       : 0.490
    Stream size                              : 19.1 GiB (92%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
  2. Maybe it's a bug in MakeMKV?
    Have you tried updating MakeMKV to v1.9.0 and recreating the mkv to test?
  3. Member wulf109's Avatar
    Jul 2002
    Just burn the ISO with Imgburn.
  4. Yes, tried updating makemkv, no difference. I don't have bluray player, and I use Serviio to stream the files to Tv, so I don't see how burning the ISO would help.
    I'll use mkvmerge and/or tsMuxer when Makemkv won't work I guess. Its just annoying that I can't see whats wrong from file info, before downloading other 30gb remuxes
    canada
    The problem is that your d/l other peoples rips which means anything can be wrong with them.
