  1. Member jseidel's Avatar
    Aug 2013
    Illinois USA
    I recently did the auto update to Pot Player 64 bit version 1.6.51480. Whatever desktop background I choose now shows through any video I play similar to a watermark. The design on the wallpaper shows faintly through the videos. Never had this before or anything like it. A setting I need to change or should I roll back to previous version?
    My specs:
    Cooler Master Elite 430
    Asus P8Z68-V PRO/GEN3
    Intel Core i5 2500K, 3.30 GHz
    ADATA 8 GB DDR3
    EVGA GTX 560 1GB PCIe
    Sound Blaster Recon3D PCIe
    1 TB Seagate Barracuda 7200 RPM
    P/S: Corsair GS800
    Windows 8.1 Pro 64 bit with Media Center
    Thanks in advance.
    J.
  2. Member jseidel's Avatar
    Aug 2013
    Illinois USA
    Changed to a different skin, Metro X, and the transparency is gone.
    J.
    Jan 2012
    Victoria, Australia
    Slide the transparency slider (it's next to the minimize icon) all the way to the right
  4. Member jseidel's Avatar
    Aug 2013
    Illinois USA
    This is how the top corner, including where the "transparency slider" looks with the Metro skin:
    Maybe the transparency went away because the control isn't there?
    Thanks,
    J.
