I just bought this and I've made two attempts to copy a VHS to DVD using the instructions in the manual. I selected XP quality (not sure if that matters). When finished, it says that it finalized the disc 100%. I'm able to play the DVD using the Funai DVD player. I am NOT able to play/view the DVD in 5 different DVD readers/recorders connected to my PCs. They all tell me it is a blank disc or has no data. What's going on? I wanted to convert these VHS tapes to DVD and then convert them to MP4/MKV to store them on my hard drives. Thanks!
P.S. - I'm using DVD-R discs like the manual says I should.
I opened ImgBurn and it tells me that the state of the last session is incomplete:
Disc Information:
Status: Incomplete
State of Last Session: Incomplete
Erasable: No
Free Sectors: 1,249,888
Free Space: 2,559,770,624 bytes
Free Time: 277:47:13 (MM:SS:FF)
Next Writable Address: 1048000
MID: MCC 02RG20
Supported Write Speeds: 2x, 4x, 6x, 8x
So does that mean the Funai is not finalizing the disc properly? -
Nevermind! I thought it was finalizing the disc after it was done recording but it must have been doing something else. Turned the page in the manual and it has a section for finalizing the disc.
