Results 1 to 16 of 16
  1. How can i download cc subtitles from any video (not youtube)?
    I try with idm but subtitles aren't on video....?
    Flash or html5 video?
    I doubt there is one program that supports all such subtitles.
  3. Member Cornucopia's Avatar
    How do you know they aren't on there? They're supposed to be closed (aka HIDDEN) until you turn them on. You can only test for their existence using a player known to support them in that supplied/stored format.
    And, they are part of the video stream, so you cannot download them separately.
    More info needed...
  4. I check with mkvmerge if it is any subtitles on this video but it dosnt show any...
    Aug 2006
    Check with MediaInfo too. You might find it has EIA-608 text streams.
  6. Originally Posted by usually_quiet View Post
    No it not detect any subtitle...
  7. Do you have link to the video stream?
  8. Originally Posted by roma_turok View Post
    Unfortunately i can't but i can tell you that video is on videomeg
  9. Originally Posted by Baldrick View Post
    I think it is html5 video
  10. Probably subtitles part of video and cannot be separated or download separately
    like this: http://videomega.tv/?ref=ZQdZTLVXDLLDXVLTZdQZ
  11. Originally Posted by roma_turok View Post
    No,they arent hardcoded into video ,when i press cc button they appear.
  12. Originally Posted by albfullsoft View Post
    When its played in website?
    or when you played file in player like VLC?
  13. Originally Posted by roma_turok View Post
    On website.
  14. Originally Posted by albfullsoft View Post
    On website.
    Ok
    you can download subtitle with Google Chrome
    follow this tutorial: https://www.youtube.com/watch?v=m3wb3shS8QE
    Its SRTs files:
  15. Originally Posted by roma_turok View Post
    On website.
    Ok
    Its SRTs files:
    [Attachment 29331 - Click to enlarge]
    Thanks ,thanks man .It works.
  16. Member Cornucopia's Avatar
    In other words, those were not REAL CCs, but rather selectable subs, and much of the discussion and direction of help was misled. (For reference for future searches).
