  1. DECEASED
    Jun 2009
    Heaven
    Today we present ffmbc 0.7.2 for the intrepid guinea pigs
    I have NOT tested the pesky binary extensively, therefore play at your own risk
    Regarding the "non-native" libraries --- I've managed to compile only five of them : -/
    (zlib, xvid, x264, Lame, and faac); regarding ffmbc itself,
    the compiler returned TONS of warning messages during the process
    Anyway, here it goes, here it goes...
    https://www.videohelp.com/tools/ffmbc
    Last edited by El Heggunte; 30th Dec 2014 at 04:44. Reason: disambiguation, update download link
  2. Thanks
    hahaha j/k
    I'll report if there are any issues
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Cool, thanks for that.......
  4. DECEASED
    Jun 2009
    Heaven
    1) Thanks and thanks =^.^=
    2) Just for the notes...
    the ready-made ./configure script does not list libtwolame
    Besides, libx265, libopus and libfdk-aac remain ignored by the author of ffmbc
    "Nobody" uses Speex or Theora (and if you use them, then you are nobody :^P ),
    so I intentionally did not build them. The same decision applies to libnut, libxavs and libschroedinger
    "Uncompilable" stuff (under my MSYS+MinGW-w64 setup, at least):
    libopenjpeg, libvpx, libgsm, frei0r;
    Dependency nightmares: librtmp, libass, libfreetype, libvorbis.
    3) this is the recipe that has worked for me:
    $ export CPATH=/path-to/include
    $ export LIBRARY_PATH=/path-to/lib
    $ export PKG_CONFIG_PATH=/path-to/lib/pkgconfig
    $ ./configure --prefix=/path-to --enable-gpl --enable-nonfree --disable-ffprobe --enable-gray --disable-dxva2 --disable-avdevice --enable-runtime-cpudetect --enable-memalign-hack --enable-avisynth --enable-libmp3lame --enable-libx264 --enable-libxvid --enable-zlib --enable-libfaac
    4) Later, I will probably copy the source-code to my Mediafire directory, because GoogleDrive is getting INSANELY "jovial"
