    Dec 2004
    When I try to open Freemake Video Converter it loads and then closes on its own right after it is down loading how do I get to stop closing??
  2. I can't say for sure, but if you are still running windows 2000 you might have a problem with the download feature because it needs to use the latest .NET package. You are best contacting Freemake for advice.
    http://support.freemake.com/home
    Dec 2004
    I am using Windows 7
    Update never mind I fixed it I was having another small program and ran rouge killer I guess it fixed the problem
    Aug 2004
    PA USA
    Sounds like a .NET problem, you can try this link to the .NET 4.0 client.
    http://www.freemake.com/en/installation/videoconverter_nodotnet/&online=1/
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
