Page 7 of 7
FirstFirst ... 5 6 7
Results 181 to 210 of 210
  1. Originally Posted by tormento View Post
    Originally Posted by real.finder View Post
    you ask lazy guy to do somthing
    Lol... could you explain how prefilter auto works and with which parameters?
    http://forum.doom9.org/showthread.php?p=1773050&highlight=SMDegrain#post1773050
    and you don't need to use parameters for it, just use lsb clip with or without lsb_in (According to your input clip, not the prefilter one)
    it work by check if the prefilter clip height is doubled or not, and if it doubled it will use lsb_in=true in Dither_Luma_Rebuild (or just use ditherpost if TV_Range=false), with lsb_in in Dither_Luma_Rebuild can gave more Quality than using ditherpost then Dither_Luma_Rebuild
    And the TV_Range=off kicks in the range expansion or also the "on"?
    TV_Range=false mean no Dither_Luma_Rebuild ('Str' and 'Amp' parameters will do nothing)
  2. Ehm. Some examples for a BD input for good usage?
  3. After latest update:
    Simple x264 Launcher (Build #1060), built 2016-10-21
    Job started at 2016-12-01, 03:17:06.
    Source file : E:\in\2_14 Suicide squad (extended)\suicide_44.avs
    Output file : E:\in\2_14 Suicide squad (extended)\suicide_44.mkv
    --- SYSTEMINFO ---
    Binary Path : D:\eseguibili\media\x264 launcher
    Avisynth    : Yes
    VapourSynth : No
    --- SETTINGS ---
    Encoder : x264 (AVC/H.264), 64-Bit (x64), 8-Bit
    Source  : Avisynth (avs)
    RC Mode : CRF
    Preset  : slow
    Tuning  : <None>
    Profile : High
    Custom  : --level 4.1 --keyint 240 --vbv-bufsize 78125 --vbv-maxrate 62500 --aq-mode 2 --sar 1:1
    --- CHECK VERSION ---
    Detect video encoder version:
    Creating process:
    "D:\eseguibili\media\x264 launcher\toolset\x64\x264_8bit_x64.exe" --version
    x264 0.148.2721kMod 72d53ab
    (libswscale 4.1.100)
    (libavformat 57.50.100)
    (ffmpegsource 2.22.1.0)
    built by Komisar on Sep 23 2016, gcc: 4.9.2 (multilib.generic.Komisar)
    x264 configuration: --bit-depth=8 --chroma-format=all
    libx264 configuration: --bit-depth=8 --chroma-format=all
    x264 license: GPL version 2 or later
    libswscale/libavformat/ffmpegsource license: GPL version 2 or later
    Detect video source version:
    Creating process:
    "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe"
    Avs2YUV 0.24bm3
    > x264 revision: 2721 (core #148) - with custom patches!
    > Avs2YUV version: 0.24.3
    --- GET SOURCE INFO ---
    Creating process:
    "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe" -frames 1 "E:\in\2_14 Suicide squad (extended)\suicide_44.avs" NUL
    error: Script error: There is no function named 'ExtractU'.
    (D:/Programmi/media/AviSynth+/plugins64/SMDegrain-2016_1129�realfinder.avsi, line 767)
    (D:/Programmi/media/AviSynth+/plugins64/SMDegrain-2016_1129�realfinder.avsi, line 173)
    (E:\in\2_14 Suicide squad (extended)\suicide_44.avs, line 19)
    PROCESS EXITED WITH ERROR CODE: 1
    AFAIK ExtractU is only in development version of AviSynth+ not yet released
  4. Originally Posted by tormento View Post
    --- SYSTEMINFO ---
    Avisynth    : Yes
    VapourSynth : No
    --- SETTINGS ---
    RC Mode : CRF
    Preset  : slow
    Tuning  : <None>
    Profile : High
    Creating process:
    Creating process:
    Avs2YUV 0.24bm3
    Creating process:
    yes, you can replace ExtractU by UToY8, and ExtractV by VToY8 until it released
  5. Originally Posted by real.finder View Post
    Got it from creator
  6. Originally Posted by real.finder View Post
    10- add MDegrain4 and MDegrain5, this will make tr=4 or 5 faster
    Any idea of why now tr=6 is less effective than tr=5 and almost same as tr=4?
    Plus Pee Wee's big adventure.264 (Pee Wee's big adventure.dgi) and the script
    PHP Code:
    SetMemoryMax(8000)
    SetFilterMTMode("DEFAULT_MT_MODE"2)
    SetFilterMTMode("ChangeFPS"3)
    SetFilterMTMode("DGSource"3)
    LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
    DGSource("F:\raw\Pee Wee's big adventure.dgi")
    ChangeFPS(last,last,true)
    SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false)
    Prefetch(8
    crashes with latest beta of KNLMeansCL, while works with 0.7.7.
    To make it work with latest beta, I have to use Prefetch(7).
  7. Originally Posted by tormento View Post
    PHP Code:
    SetMemoryMax(8000)
    LoadPlugin("D:\eseguibili\media\[url=https://www.videohelp.com/software/DGDecNV]DGDecNV[/url]\x64\[url=https://www.videohelp.com/software/DGMPGDec]DGDecodeNV[/url].dll")
    Prefetch(8
    are you always use lsb=true? I found something in tr=5 without lsb and fix it now (it was copy past typo)
  8. Originally Posted by real.finder View Post
    Yes. AFAIK gives better results.
    Ok, will try.
  9. Originally Posted by real.finder View Post
    try with always_mdegrainn=true
    Files:
    pee.264
    pee.dgi
    SMDegrain.avsi + this variation to use KNLMeansCL 1.0
    Basic script and variations:
    PHP Code:
    SetMemoryMax(8000)
    DGSource("E:\in\Pee Wee's big adventure\pee.dgi")
    Prefetch(7
    encoded 2162 frames, 7.81 fps, 4015.53 kb/s, duration 0:04:36.77
    av2y [info]: E:\in\Pee Wee's big adventure\pee_44.avs: 1920x1080, 2997/125 fps, 2162 frames
    Final file size is 43.2 MB bytes.
    PHP Code:
    SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false,always_MDegrainN=true
    encoded 2162 frames, 7.72 fps, 4245.76 kb/s, duration 0:04:40.05
    av2y [info]: E:\in\Pee Wee's big adventure\pee_44a.avs: 1920x1080, 2997/125 fps, 2162 frames
    Final file size is 45.7 MB bytes.
    PHP Code:
    SMDegrain (tr=5,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false
    encoded 2162 frames, 7.00 fps, 3771.63 kb/s, duration 0:05:08.76
    av2y [info]: E:\in\Pee Wee's big adventure\pee_54.avs: 1920x1080, 2997/125 fps, 2162 frames
    Final file size is 40.6 MB bytes.
    PHP Code:
    SMDegrain (tr=5,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false,always_MDegrainN=true
    encoded 2162 frames, 6.81 fps, 3991.23 kb/s, duration 0:05:17.41
    av2y [info]: E:\in\Pee Wee's big adventure\pee_54a.avs: 1920x1080, 2997/125 fps, 2162 frames
    Final file size is 42.9 MB bytes.
    PHP Code:
    SMDegrain (tr=6,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false
    encoded 2162 frames, 6.16 fps, 3806.16 kb/s, duration 0:05:51.22
    av2y [info]: E:\in\Pee Wee's big adventure\pee_64.avs: 1920x1080, 2997/125 fps, 2162 frames
    Final file size is 40.9 MB bytes.
    PHP Code:
    SMDegrain (tr=6,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=6,TV_range=false,always_MDegrainN=true
    encoded 2162 frames, 6.12 fps, 3806.16 kb/s, duration 0:05:53.37
    av2y [info]: E:\in\Pee Wee's big adventure\pee_64a.avs: 1920x1080, 2997/125 fps, 2162 frames
    Something is going wrong, I think, in script or in latest MVTools iteration. How is possible that a 6 frame noise reduction is less effective than a 5 frame and almost equivalent to a 4?
  10. Does SMDegrain now support Avisynth+'s native 16-bit format or still relies on lsb?
  11. Originally Posted by real.finder View Post
    new edit in same post
    86s gives me error:
    [2017-02-05][19:53:58] Simple x264 Launcher (Build #1086), built 2017-01-14
    [2017-02-05][19:53:58] Job started at 2017-02-05, 19:53:58.
    [2017-02-05][19:53:58] Source file : E:\in\1_45 wave, The\wave_44.avs
    [2017-02-05][19:53:58] Output file : E:\in\1_45 wave, The\wave_44.mkv
    [2017-02-05][19:53:58] --- SYSTEMINFO ---
    [2017-02-05][19:53:58] Binary Path : D:\eseguibili\media\x264 launcher
    [2017-02-05][19:53:58] Avisynth    : Yes
    [2017-02-05][19:53:58] VapourSynth : No
    [2017-02-05][19:53:58] --- SETTINGS ---
    [2017-02-05][19:53:58] Encoder : x264 (AVC/H.264), 64-Bit (x64), 8-Bit
    [2017-02-05][19:53:58] Source  : Avisynth (avs)
    [2017-02-05][19:53:58] RC Mode : CRF
    [2017-02-05][19:53:58] Preset  : slow
    [2017-02-05][19:53:58] Tuning  : <None>
    [2017-02-05][19:53:58] Profile : High
    [2017-02-05][19:53:58] Custom  : --level 4.1 --keyint 240 --vbv-bufsize 78125 --vbv-maxrate 62500 --aq-mode 2 --sar 1:1
    [2017-02-05][19:53:58] --- CHECK VERSION ---
    [2017-02-05][19:53:58] Detect video encoder version:
    [2017-02-05][19:53:58] Creating process:
    [2017-02-05][19:53:58] "D:\eseguibili\media\x264 launcher\toolset\x64\x264_8bit_x64.exe" --version
    [2017-02-05][19:53:58] x264 0.148.2744kMod b97ae06
    [2017-02-05][19:53:58] (libswscale 4.3.101)
    [2017-02-05][19:53:58] (libavformat 57.58.101)
    [2017-02-05][19:53:58] (ffmpegsource 2.23.0.0)
    [2017-02-05][19:53:58] built by Komisar on Dec 3 2016, gcc: 4.9.2 (multilib.generic.Komisar)
    [2017-02-05][19:53:58] x264 configuration: --bit-depth=8 --chroma-format=all
    [2017-02-05][19:53:58] libx264 configuration: --bit-depth=8 --chroma-format=all
    [2017-02-05][19:53:58] x264 license: GPL version 2 or later
    [2017-02-05][19:53:58] libswscale/libavformat/ffmpegsource license: GPL version 2 or later
    [2017-02-05][19:53:58] Detect video source version:
    [2017-02-05][19:53:58] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe"
    [2017-02-05][19:53:59] Avs2YUV 0.24bm5
    [2017-02-05][19:53:59] > x264 revision: 2744 (core #148) - with custom patches!
    [2017-02-05][19:53:59] > Avs2YUV version: 0.24.5
    [2017-02-05][19:53:59] --- GET SOURCE INFO ---
    [2017-02-05][19:53:59] Creating process:
    [2017-02-05][19:53:59] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe" -frames 1 E:\in\1_45WA~1\wave_44.avs NUL
    [2017-02-05][19:53:59] error: Evaluate: operand of `!' must be boolean (true/false)
    [2017-02-05][19:53:59] (D:/Programmi/media/AviSynth+/plugins64/SMDegrain-3.1.2�86s�realfinder.avsi, line 101)
    [2017-02-05][19:53:59] (E:\in\1_45WA~1\wave_44.avs, line 13)
    [2017-02-05][19:53:59] PROCESS EXITED WITH ERROR CODE: 1
    I usually modify line 821 to use KNLMeans 1.0 but always worked and I don't think it's this:
    cnl     = chroma && fullchr ? "YUV" : "Y"
                                                  nlc     = Eval("nlc.KNLMeansCL(D=d, A=a, h=h,lsb_inout=lsb_in || lsb,device_type=device_type,device_id=deviceid,channels=cnl" + knlm_params + ")")
  12. Originally Posted by tormento View Post
    [2017-02-05][19:53:59] PROCESS EXITED WITH ERROR CODE: 1[/CODE]
    fixed
  13. Originally Posted by tormento View Post
    @real.finder
    Would you try a build with DGDenoise? http://rationalqm.us/board/viewtopic.php?f=5&t=506&start=90
    don't have nvidia
  14. Originally Posted by real.finder View Post
    @real.finder
    don't have nvidia
    Me yes.
    Write the code and I will test it for you
  15. Originally Posted by tormento View Post
    @real.finder
    don't have nvidia
    Me yes.
    I can't cuz I will not see what is going on in denoise, you can always use prefilter with clip, so it's not a big problem
  16. Now that Masktools too has been ported to high bit, what else is needed but KNLMeansCL to create a complete and I hope faster 16 bit environment script?
  17. Originally Posted by tormento View Post
    will did new edit soon, but you still can't use all options, there are many plugins don't has native high bit yet
  18. When using your latest version of SMDegrain, I get this: https://forum.videohelp.com/images/imgfiles/NrbR1kX.png
    Thoughts? Is there an updated dependency I'm missing somewhere?
    Edit: I should note I am using the latest mvtools-pfmod and Masktools2-pfmod but the problem presents even with those reverted.
    Also using Avisynth+ r2455-MT from pinterf
    Edit2: I guess I should also just get to the point for my base problem and why I'm trying your version. I upgraded to a Ryzen R7 1800X from an Intel i7-4790k. Every time I use smdegrain on my new Ryzen box regardless which version, it crashes several hundred frames into the encode. No reason given for why. It just does. Any thoughts on that?
    Edit3: So it turns out that fftw doesn't work on AMD Ryzen. dfttest and fft3dfilter both fail to see more than 240 frames, which is causing the issue. I tried to compile new .dlls but the configure script for the newest version 3.3.6-pl1 doesn't have the ability to make a portable binary for some reason.
    Regardless, I'm still interested why I get those duplicated images using your version.
  19. Originally Posted by begna112 View Post
    with what script? and can you upload sample from source?
  20. Working script:
    PHP Code:
    SetMemoryMax(8000)
    DGSource("E:\in\1_54 ferroviere, Il\ferroviere.dgi")
    CompTest(1)
    SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=0)
    Prefetch(6
    Non working script:
    PHP Code:
    SetMemoryMax(8000)
    CompTest(1)
    SMDegrain (tr=6,PreFilter=4,thSAD=600,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=0)
    Prefetch(6
    Last version of every plugin and script. Something is wrong with thSAD=600. Any idea? A couple of versions ago it worked fine.
  21. Originally Posted by tormento View Post
    Working script:
    PHP Code:
    SetMemoryMax(8000)
    CompTest(1)
    Prefetch(6
    Non working script:
    PHP Code:
    SetMemoryMax(8000)
    CompTest(1)
    Prefetch(6
    I don't has gpu so I set PreFilter to 1 and work here (test without mt and without the others filters you have in script)
    and what you mean by not work?
  22. Originally Posted by real.finder View Post
    Strangely enough RedStone release preview 3 solved problems.
  23. Hi everyone i have Nvidia ghraphic card but i get an i get strange error in smdegrain when i try to use Prefilter=4 I download the KnlMeansCL v.1.0.2 but no luck, please can someone help,thanks
    Edited
    After Uninstalling Avisynth 2.6MT i installed Avisynth 2.6.0.6 and i think there was something in older avisynth which was not reading KnlmeansCL properly or not recognising it but KNLMeansCL v1.0.2 works now with Avisynth 2.6.0 .
  24. With Avisynth+ now supporting native high-bit-depth, and MaskTools2 and MvTools2 also supporting high-bit-depth, is anyone interested in modifying SMDegrain to work with full native high-bit-depth?
    In the best world, you could simply call SMDegrain with a 16-bit native clip and it would process it all in HBD. In practice, it returns errors. Some side libraries (that probably have HBD replacements) haven't been ported to HBD yet, and a few minor issues can happen along the way.
    It shouldn't be very hard but someone's got to do it, sooner or later.
    I just created a thread here on the specific topic of porting it to HBD
  25. Hello real finder your SMDegrain update seems interesting , i was using v3.1.2d but today i switch to v.3.1.2.93s your mode, but i am facing problem with v.3.1.2.93s not working with prefilter=4 but v3.1.2d does work with prefilter=4 don't know why it is not working with your moded SMDegrain, can u help me make it work i m currently using KNLMeansCL v.1.2 for test. thank you for your mod.
    AviSynth Script error:
    Script error: KNLMeansCL does not have named argument "stacked"
    (SMDegrain v.3.1.2.93s.avsi, line 848)
    (SMDegrain v.3.1.2.93s.avsi, line 796)
    (SMDegrain v.3.1.2.93s.avsi, line 196)
  26. Originally Posted by BÌG•bµdd View Post
    you need last one https://github.com/Khanattila/KNLMeansCL/releases/
    for older you can use 3.1.2.92s
  27. This has been my go-to MDegrain3 script for use with high-ISO grain on 1080p footage:
    AviSource("d:\fs.avi")
    ConvertToYV12
    super = MSuper()
    backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4)
    forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4)
    backward_vec4 = MAnalyse(super, isb = true, delta = 4, overlap=4)
    forward_vec4 = MAnalyse(super, isb = false, delta = 4, overlap=4)
    backward_vec6 = MAnalyse(super, isb = true, delta = 6, overlap=4)
    forward_vec6 = MAnalyse(super, isb = false, delta = 6, overlap=4)
    MDegrain3(super,backward_vec2,forward_vec2,backward_vec4,forward_vec4,backward_vec6,forward_vec6,thSCD1=400,thSAD=400)
    LSFmod(strength=300)
    I've managed to get close to the result with SMDegrain v.3.1.2.93s, but I don't think it's an improvement for this particular footage and it's a bit slower:
    ConvertToYV12
    SMDegrain(tr=5,thSAD=500,thSCD1=400,prefilter=4,refinemotion=true)
    I've also tried contrasharp=100 instead of the separate LSFmod line, and that's OK but the separate LSFmod line is faster.
    Is there a direct equivalent of my first MDegrain3 script in SMDegrain? I would like to use that as a starting point for further tweaking.
  28. Originally Posted by Bubblevision View Post
    ConvertToYV12
    super = MSuper()
    ConvertToYV12
    to speed up remove the refinemotion=true and set tr=3
    LSFmod in SMDegrain used this settings here
  29. Originally Posted by real.finder View Post
    thank you for helping a hand real finder, it is working perfect now will do some test tomorrow thanks again for your great mod function , you doing really wonderful work keep it up and good luck.
    Bubblevision few more option u can choose
    SMDegrain(tr=5,thSAD=500,thSCD1=400,prefilter=4,re finemotion=true)### for hd footage try blksize=16, overlap=8, and try pel=2 ,subpixel=2
