    Dec 2014
    Portugal
    Hi...
    I'm having trouble with these two programs, I have several BD50 and try to open the BDMV folder on AVCHDCoder and always gives error, says "NO PLAYLISTS FOUND", however Stream folder has several videos in M2TS!?
    I do not understand why the error?
    Herewith I tried with other software the BD Rebuilder, but this also gives error to open the BDMV folder, "Runtime Error 52 Bad file name or number"?!
    I did all tests in both sftwares and everything went OK, I have everything installed so do not understand these errors!
    PLEASE can anyone HELP ME?!
    Since now I thanks for attention.
    Respects.
  2. It would help if you told us:
    - Your operating system. (If it's Win7 or higher, you can right click the BDRB executable and select run as administrator; BDRB will then offer to configure itself. There are also reports from some Win8 users that they had to run a specific version of BDRB in compatibily mode.)
    - Which decrypter used (AnyDVDHD, etc).
    - BDRB version used. (Error 52 fixed in v. 45.05).
    - Necessary programs installed? (Avisynth, ffdshow, Haali).
    The fact that neither AVCHDCoder nor BDRB works leads me to suspect that either the helper programs are not installed or you're trying to open a disc that has not been decrypted.
    Correct versions of the needed extra programs here:
    http://forum.doom9.org/showthread.php?t=143716
    [EDIT] Welcome to the forum.
    Pull! Bang! Darn!
    Dec 2014
    Portugal
    Hi, thanks for response.
    My operating system is windows 8, yes I executable the program run as administrator so it is not the fault there.
    As it was not me that rip, I do not know which decrypter was used.
    The version that I use is the last, BD Rebuilder 0.50.01 and I installed Avisynth, ffdshow, Haali, everything is OK there!
    The BDs are already been decrypted, I got it in a forum AsianDVDClub.
