  1. Hi! I know very little about conversion so please forgive my ignorance. I've looked on the forums but I can't seem to find an answer(might be due to my ineptitude).
    I'm using AVStoDVD to convert an MKV. When encoding the video, the progress stalls. The program doesn't freeze, it says it is working but the progress bar doesn't move at all(I've left it for hours before). Here are the settings and preferences from AVStoDVD followed by the encoding log. Any help is greatly appreciated. Thank you.
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 3321/4450 MB (75%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\VKS\Videos
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 8500
    Video Profile Level 2: 2500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 3
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: G:\
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow at runtime: 1
    Save General Settings: 0
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 3111.8 MB
    Encoding Parameters: -ini "C:\Users\VKS\AppData\Local\Temp\DVD_7_Filename.72 0p.NF.WEBRip.DD5.1.x264-NTb.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\VKS\AppData\Local\Temp\DVD_7_Filename.NF. WEBRip.DD5.1.x264-NTb_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\VKS\Videos\DVD_7_Filename.NF.WEBRip.DD5.1 .x264-NTb.m2v
    *LOGFILE C:\Users\VKS\AppData\Local\Temp\DVD_7_Filename.NF. WEBRip.DD5.1.x264-NTb.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 8500
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *PULLDOWN
    *BIAS 80
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH C:\Users\VKS\AppData\Local\Temp
    *WAIT 2
    Nov 2003
    West Texas
    I've always used the HC encoder in a 2 pass configuration instead of one.
    If that doesn't help, try using ffmpeg for the encoder.
  3. Post the hcenc log file as well . It should be at this location
  4. Hi Satoree,
    have you tried to use the default AVStoDVD settings? Do you get problems too?
    I would suggest you to:
    1. Read carefully the FAQ video section of AVStoDVD Help
    2. Make sure your system can handle matroska containers properly with DirectShow approach ('Codecs'/'Build Directshow Filters Graph')
    3. Run the project with default settings
    4. Post here the COMPLETE log file
    Bye
    MrC
    AVStoDVD Homepage
  5. Member Seeker47's Avatar
    Jul 2005
    What kind of video is inside the MKV container ? I've run across some AVC sources that sent AVStoDVD jobs into the Twilight Zone, regardless of how I fiddled with the settings. Never really found out what was causing this, either.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  6. Downloaded MKVs can be very very strange. Every now and then, I encounter one that takes forever to process thru a DVD conversion program, and the resulting DVD conversion winds up accelerated to warp speed (two hour MKV movie plays back in two seconds after conversion). When this happens, I run the weird MKV thru a utility like MKVtools, remux it to another format/container like AVI, then load that AVI into the DVD conversion software. The problem title then converts properly in the normal amount of processing time.
