I hope not but it work on my friend hd tv from vga to vga. I wonder is there anymore settings I need to play around that I miss outIt is entirely possible that some older XP laptops would not be powerful enough to display video on a second monitor at an HD resolution.Thanks I know how to use a search engine. I came across something similar to that page before. It didn't click right away cloning is the same as dual view. I tried and I don't think it works. thanks for your help.http://support.microsoft.com/kb/307873 Look at the Dualview section. Don't you know how to use a Search engine?Where do I find this option? Maybe my laptop doesn't have it.Can your old XP laptops play the video and produce a picture on their own display? If not, the vga to hdmi converter is not the cause of your problem. Yeah . I have connected my old laptop to my friends widescreen tv with vga input and s video input and both worked.
Can your old XP laptops' video cards output video at one of the converter's supported input resolutions, say a TV resolution like 720p or a widescreen monitor resolution like 720x1280 or 768x1366? . I think so.
What happens if you set up the laptop to clone its display on the TV instead of extending it?
Results 31 to 33 of 33
What are that laptop models that you are using?
This is more likely a hardware limitation (ie: cpu and/or video card) and not a software issue.Google is your Friend -
