I'm making SVCD's using VCDEasy and when the program goes to compile the .bin file I get a
"Padding on the fly. Hope that's OK." message.
The program then proceeds to add 105 MB of padding to my SVCD jumping it from 770 MB to 885, clearly to large. My .mpg files were created using TMPGEnc with a variable bit rate (Range 2200 max to 300 min) and a quality of 65.
The questions are:
Is there anyway to turn off the padding in VCDEasy?
How can I create my original mpg's so they don't have to be padded?
What is the goal of the padding?
To avoid padding, you need to have multiplexed your file correctly first. I suggest that you remultiplex your MPEG-2 file with bbMPEG before bringing it into VCD Easy/VCDImager.
Regards.Michael Tam
w: Morsels of Evidence
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 17:56 -
Add padding to videos
By marioval in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2009, 06:22 -
Padding in DVD Author 3
By pepegot1 in forum Authoring (DVD)Replies: 6Last Post: 16th May 2009, 15:21 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17 -
Left and right black padding, not working in .9x r2?
By CDickey370 in forum ffmpegX general discussionReplies: 1Last Post: 7th Sep 2007, 07:52
