    Dec 2014
    My copies of Game of Thrones 3 won't play. The other 2 seasons recorded and played just fine. I am using verbatim discs that work well on other DVD's. I can see the data on the discs on my computer but it won't play on any of my blu-ray players. Any suggestions?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What program did you decrypt your ORIGINAL DVDs or ORIGINAL BLU-RAY discs with?
    Dec 2014
    I am using Leawo 7.1.0.8
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    That is a converter, not a decrypter.
  5. Banned
    Freedonia
    You'll have to install MediaInfo and use it to open a problem file and post the results here. We might be able to tell from that what the problem is.
