I'm having issues with my cheap no-brand chinese HDMI PCI-e capture card. . . serves me right I suppose. I'm capturing 1920x1080 using Virtualdub, Huffy video codec. The picture is always great, but my sound will spontaneously change speed and go out of sync, usually half an hour into a capture. It's quite difficult to explain so I've uploaded a short clip (17MB, x264/AAC) - it's also creepy as hell :P
The PC ought to be capable - overclocked i5 4670k, 8GB ram, capturing to 4TB WD Black hard disk. I've tried a bunch of stuff without much luck to try to prevent it happening. Network disconnected, preview window shrunk/disabled completely, but it still happens. Virtualdub reports zero frames dropped at the end of the capture.
CPU usage during capture is 40 to 60% according to VirtualDub - I assume this is of a single CPU core as VirtualDub only ever seems to use a single thread, so this could just be a case of antiquated software. CPU use could well be occasionally spiking and failing to keep up.
I'm very open to suggestions for better capture software, either free or not crazy-expensive. The capture card came with a Honestech DVR package that doesn't seem to suffer this issue, but will only capture to MPEG2 with all the interlacing intact, and that gives lousy results.
AmaRecTV is alternative software that you could try. Regardless of the capture software, I would choose to capture an interlaced source as interlaced. If de-interlacing was necessary I would de-interlace afterwards and not in real time during capture, assuming the option to do it later was available to me.
Can you try capturing at a lower resolution or bitrate to see if the problem is repeatable?
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Capture -> Timing -> Do not resync between audio and video streams. I assume the current selection is "Sync audio to video by resampling the audio to a faster or slower rate".
Also, always capture uncompressed audio and uncheck "Enable audio playback".
The video seems to exhibit black crush, aliasing, and is deinterlaced to half-rate. But if you're happy with it I won't argue with you. -
Been impressed with AmaRecTV so I may go on using that.
vaporeon - Thanks for the note on timing options, that's not a menu I've explored before. You're right, it was set as you described by default.
I must admit I had to Google black crush, but that sounds like something I wouldn't have control over as my source path is all digital. I just threw the video into handbrake to illustrate the point so I'm not too worried about the deinterlace this time :P
