i had a question about h264 format, i read wikipedia article about that by my question is not answered.
1- in the table of levels the maximum number of "Luma samples/s" belong to level 5.2 which is 530,841,600
for resolution of 3840x4320(SBS 3D, up and down) it only supports 32 fames. how come i have a video with that resolution in High@5.1 in 60 fps?
2- LG claim to be able to play 4k videos and 60 fps content. even if it can play 4K@30fps it should support 5.1 level (3840*2160*30=248832000). so why it didnt play my samples in LG center? i have 2 sample none of which were played:
Code:Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 491 MiB Duration : 10mn 34s Overall bit rate : 6 491 Kbps Movie name : Big Buck Bunny, Sunflower version Performer : Blender Foundation 2008, Janus Bager Kristensen 2013 Composer : Sacha Goedegebure Genre : Animation Encoded date : UTC 2013-12-16 18:03:30 Tagged date : UTC 2013-12-16 18:03:30 Comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net ©com : Jan Morgenstern Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10mn 34s Bit rate : 6 000 Kbps Maximum bit rate : 29.1 Mbps Width : 1 920 pixels Height : 2 160 pixels Display aspect ratio : 0.889 Frame rate mode : Constant Frame rate : 60.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.024 Stream size : 454 MiB (93%) Writing library : x264 core 115 Encoding settings : cabac=1 / ref=8 / deblock=1:1:1 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60 Encoded date : UTC 2013-12-16 18:03:30 Tagged date : UTC 2013-12-16 18:03:37 Audio #1 ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 6B Duration : 10mn 34s Bit rate mode : Constant Bit rate : 160 Kbps Maximum bit rate : 165 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 12.1 MiB (2%) Writing library : LAME3.99r Encoding settings : -m j -V 4 -q 3 -lowpass 17.5 -b 160 Encoded date : UTC 2013-12-16 18:03:37 Tagged date : UTC 2013-12-16 18:03:37 Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : ac-3 Duration : 10mn 34s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 24.2 MiB (5%) Encoded date : UTC 2013-12-16 18:03:37 Tagged date : UTC 2013-12-16 18:03:37Code:Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 945 MiB Duration : 10mn 34s Overall bit rate : 12.5 Mbps Movie name : Big Buck Bunny, Sunflower version Performer : Blender Foundation 2008, Janus Bager Kristensen 2013 Composer : Sacha Goedegebure Genre : Animation Encoded date : UTC 2013-12-20 20:17:03 Tagged date : UTC 2013-12-20 20:17:03 Comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net ©com : Jan Morgenstern Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10mn 34s Bit rate : 12.0 Mbps Maximum bit rate : 66.0 Mbps Width : 3 840 pixels Height : 4 320 pixels Display aspect ratio : 0.889 Frame rate mode : Constant Frame rate : 60.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.012 Stream size : 908 MiB (96%) Writing library : x264 core 120 Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60 Encoded date : UTC 2013-12-20 20:17:03 Tagged date : UTC 2013-12-20 20:17:07 Audio #1 ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 6B Duration : 10mn 34s Bit rate mode : Constant Bit rate : 160 Kbps Maximum bit rate : 165 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 12.1 MiB (1%) Writing library : LAME3.99r Encoding settings : -m j -V 4 -q 3 -lowpass 17.5 -b 160 Encoded date : UTC 2013-12-20 20:17:06 Tagged date : UTC 2013-12-20 20:17:07 Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : ac-3 Duration : 10mn 34s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 24.2 MiB (3%) Encoded date : UTC 2013-12-20 20:17:06 Tagged date : UTC 2013-12-20 20:17:07
Results 1 to 13 of 13
My guess it is a combination of:
1. LG is fudging or being rigid/stupid on certain parameters of Level compliancy
2. Wikipedia is mis-quoting slightly
3. MediaInfo isn't giving all the necessary info to determine this
4. Those files cheated in their x264 encoding/muxing
5. You are missing something else about compliancy requirements
Scott -
Maybe the maximum frame rate changes according to the number of reference frames used. I'm not really sure, but the second encode has ref=4 while for the first it's ref=8. Did you do that or did the encoder decide? Did you specify Level 5.1?
What LG player are you using? Not that I know much about LG but a little info might help. If you're referring to an external player and HDMI..... I picked a random 4K LG TV and looked at the manual. It indicated you should use the "HDMI In 3" port for 4k stuff. It's the only high resolution, high frame rate friendly HDMI port.
Edit: It appears the x264 encoder doesn't force you to stick to the appropriate frame rates or resolutions for a given level. I tried a quick 640x480 encode while specifying Level 1.0 and the following was added to MeGUI's log file:
[Information] [19/12/14 8:45:39 PM] changing --ref to 0
[Warning] [19/12/14 8:46:04 PM] x264 [warning]: frame MB size (40x30) > level limit (99)
[Warning] [19/12/14 8:46:04 PM] x264 [warning]: DPB size (4 frames, 4800 mbs) > level limit (0 frames, 396 mbs)
[Warning] [19/12/14 8:46:04 PM] x264 [warning]: MB rate (30000) > level limit (1485)
[Information] [19/12/14 8:46:04 PM] x264 [info]: profile High, level 1.0
Lots of warnings, but it still encoded (and set Level 1 according to MediaInfo). Then again, this is what MediaInfo displays for ref frames:
Writing library : x264 core 142 r2491 24e4fed
Encoding settings : cabac=1 / ref=1 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 /Last edited by hello_hello; 19th Dec 2014 at 04:00.
Anyone can flag a video file as any Profile and Level that they want. See H264 Level Editor, for example. That's all that MediaInfo reports. It may or may not accurately reflect the properties of the video.
thanks for answering dear hello_hello
i did not do anything, i have just downloaded from the makers website
actually i am buyning a LG UB85000GI, sorry if the website is in farsi, i couldn't find it in other regionsLast edited by darknesslord; 19th Dec 2014 at 14:08.
Just because it's beyond the spec doesn't mean it can't exist. h.264 compressed video is just a series of compressed frames. You can put whatever you want for the frame rate at the container level (depending on the container). You could specify a thousand framers per second if you wanted.
that is right, but what ever frame rate you choose the player should have the capability to play it
my problem is that if LG claims that its UB85000GI TV can play 4k@60p it should support level 5.2, i have asked from them, they say that the TV can play 4k@60p from a usb memoryLast edited by darknesslord; 20th Dec 2014 at 00:36.
I thought the days of there being an acceptable number of dead pixels was a thing of the past. LG don't seem to think so. From the manual:
Dot Defect
The panel is a high technology product with resolution of two million to six million pixels. In a very few cases, you could see fine dots on the screen while you’re viewing the TV. Those dots are deactivated pixels and do not affect the performance and reliability of the TV.
I like that. The performance of the TV is un-effected by the number of working pixels.
Are you sure the TV's supposed to play 4k AVC video at 60fps. It appears to have a built-in HEVC decoder. This is all the info I could find. Different model number, but probably still applicable:
http://www.lg.com/us/tvs/lg-55UB9500-led-tv
HEVC Decoder
The recently developed HEVC (short for High Efficiency Video Coding) compression format is essential to ULTRA HD/4K, enabling next-generation video playback to meet the demands of UHD TVs. 4K video uses HEVC, and so the built-in HEVC decoder on this LG ULTRA HD television makes it ready to display 4K content.
It's possible the media player supports higher resolutions for HEVC than it does for AVC.
http://en.wikipedia.org/wiki/High_Efficiency_Video_Coding#Tiers_and_levels
Unfortunately the manual I downloaded tells you absolutely nothing in respect to the formats it'll play. There's a page dedicated to explaining how to plug a USB device into one of the USB ports, but you're on your own from there. Even today some players are more enthusiastic about the AVC resolutions they support than they are when it comes to MPEG4 ASP, so chances are there's a similar thing happening with players supporting HEVC. -
i don't know about AVC but it is supposed to play 4K@60p
you can be right, but i downloaded a 4K HEVC but it was just video stream (in .h265 extension, no audio). and the TV didn't play that too
shoould i mux that video with an audio? if yes, what is the best audio format, container and muxer for that job -
You'd probably need to mux it into a container. I think MKVMergeGUI supports h265 these days. I shouldn't imagine it'd need to also include audio.
It's very early days for 4k and h265 so you're in what for most of us would be uncharted territory.
i have reencoded + chagned level of a 3D 1920x800 movies into different levels from 3.2 to 5.1 and i see which of are playable in UB85000GI and i will present results here
thanks to every one for answering
