First time asking for help...please...someone help
this is a website basically focus on online education and my college want my help downloading it
here is the website:
first i use this method with rtmpdumpCode:https://www.zenius.net/c/2124/review-turunan-teori
and i found the rtmps link.. i think it will be easy and almost there.. follow the steps and then i've got an error when i'm trying to download it with rtmpdumpCode:https://forum.videohelp.com/threads/311893-How-to-download-flash-video-RTMP-RTMPE-streams-using-free-software
could someone help me? please give me a solution
i have tried another streaming record for rtmp video like streamtransport, vmrecorder, orbit downloader, replay media catcher, and many more but nothing worked
i don't know where went wrong... or please some kind person give me a new way of downloading
Thanks All
Results 1 to 11 of 11
Hi fahri378 ,
I have not been able to catch your link .
Below an other search ( from https://www.youtube.com/user/ZeniusEduChannel ).
Code:===== GENERAL PROCESS ===== youtube-dl -F https://www.youtube.com/user/ZeniusEduChannel/videos >list_vid.txt => you'll get a file 'list_vid.txt' => in witch ( at the moment ) ==> are staying 62 names . ===> do a search for 'Downloading webpage' to see each one ==> for each one are indicated differents formats ==== example for one ==== [info] Available formats for TH0mcyA5TWE: format code extension resolution note 140 m4a audio only DASH audio , audio@128k (worst) 139 m4a audio only DASH audio 49k , audio@ 48k (22050Hz), 1.05MiB 140 m4a audio only DASH audio 97k , audio@128k (44100Hz), 2.10MiB 141 m4a audio only DASH audio 193k , audio@256k (44100Hz), 4.19MiB 160 mp4 144p DASH video , video only 160 mp4 192x144 DASH video 68k , 15fps, video only, 696.20KiB 133 mp4 240p DASH video , video only 133 mp4 320x240 DASH video 130k , 15fps, video only, 1.14MiB 134 mp4 360p DASH video , video only 134 mp4 480x360 DASH video 121k , 15fps, video only, 950.65KiB 135 mp4 480p DASH video , video only 135 mp4 640x480 DASH video 191k , 15fps, video only, 1.46MiB 17 3gp 176x144 36 3gp 320x240 5 flv 400x240 43 webm 640x360 18 mp4 640x360 (best) ==== Supposing you are interested by format 135 and 141 You could write in a batch file ; the syntax : youtube-dl -f 135+141 https://www.youtube.com/watch?v=TH0mcyA5TWE -o "a-01_intro_to_adverb_clause.mp4" If no kind of format selected it's always the best choosed ; example : youtube-dl https://www.youtube.com/watch?v=TH0mcyA5TWE -o "a-01_intro_to_adverb_clause.mp4" ==========================
Cheers .Code:===== For Specific PLAYLIST ===== ( from https://www.youtube.com/user/ZeniusEduChannel/playlists ) Matematika SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAFeZtkGA2dQmN7oDOtIoYy2 -o >lst_Matematika.txt Biologi SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAEjrlP6Wh4ELYmty728dWcI -o >lst_Biologi.txt Fisika SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAHH8UsnCeuLBmS0iJrkXcSz -o >lst_Fisika.txt Ekonomi SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAFh5ci0-1eLp83YKWQ-ugll -o >lst_Ekonomi.txt Sosiologi SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAGxOuUFzFVvJqBLTW1CQFCr -o >lst_Sosiologi.txt SMP youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAF9loRzsmUcUfE05ziCYOEJ -o >lst_SMP.txt Kimia SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAHwRamsdrjIX7U_rpd24CDE -o >lst_Kimia.txt example => playlist Kimia SMA: Collected 5 video ids (downloading 5 of them) Bahasa Inggris SMA youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAEYs1FanfGaR7XBPIL9Jiml -o >lst_Bahasa.txt Intro and Tutorial youtube-dl -F https://www.youtube.com/playlist?list=PLOALRnUt6kAE74HSU2ODld2vo95D3Yj2y -o >lst_Intro.txt ==========================
Hi ponens,
Can you explain to me how to use that? I don't understand it. Sorry.. and thank you for the answer
Hi aazerty,
Thanks mate for the link. But, i want to save video on the website because there's more complete and updated. On the youtube, there's only a few videos.. like demo. By the way, what program did you use to catch that links?
Any other solution please? -
Hi ponens ,
> ... ios-url in the source
I have understood your meaning .
Many thanks !!!
Hi fahri378 ,
What I have done .
Regards .Code:=== In Firefox : _ launch https://www.zenius.net/c/2124/review-turunan-teori _ after the video has began put it in 'pause' _ <Ctrl U> or go at 'Tools' => 'Web developper' => click on 'Source of the page' _ in the new page search for 'data-ios-url' _ on your right you'll get the address "https...cz01" _ copy it ==== ==== Open a text editor => paste the previous copy . Now you can create a batch file ( like below ) @echo on rem https://www.zenius.net/c/2124/review-turunan-teori ffmpeg -re -i "https://...cz01" -vcodec copy -acodec copy -f mpegts Z_review-turunan-teori.ts pause :end Save the file as 'Z_review-turunan-teori.bat' in the ffmpeg's directory ==== ==== Launch 'Z_review-turunan-teori.bat' . ---- Process ---- ffmpeg version N-53284-gd0a34ae Copyright (c) 2000-2013 the FFmpeg developers built on May 20 2013 01:02:45 with gcc 4.7.3 (GCC) ..... Stream mapping: Stream #0:1 -> #0:0 (copy) Stream #0:2 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 4522 fps= 15 q=-1.0 Lsize= 3506kB time=00:05:01.48 bitrate= 95.3kbits/s video:791kB audio:1821kB subtitle:0 global headers:0kB muxing overhead 34.222301% ==== I got 'Z_review-turunan-teori.ts'
Hi aazerty,
Thanks for your solution. This method is worked for the first video. But, if i switch to another videos(i click this) in the ios-url source i still got the same link as the first video. So, i downloaded the same video again..
Can you help me how to download the next video? Thank you very much aazerty
