    Dec 2014
    Northern Ireland
    When I go to copy to media, a message comes up saying "an unsupported media is inserted".
    I have been able to copy to DVD previously.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    http://www.shouldiremoveit.com/HD-Writer-LE-21970-program.aspx
    HD Writer software, included with the(Panasonic) camcorder, makes it easy to play or edit videos on your PC and have more fun when the shooting's done.
    Either your burner is dying or try REAL burning software like ImgBurn.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Or you are using the wrong media as the error indicates. Not all burners support all media brands/types.
    It also depends on the source if you are trying to burn ISO files.
    Google is your Friend
