  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    I use tsMuxeR GUI 2.6.12 in order to demux DVB-S2 recorded HD footage.
    The footage is ...
    Video: 1920x1080@25 H.264
    Audio1: AC3 5.1 48000Hz ger
    Audio2: AC3 2.0 48000Hz eng
    tsMuxeR shows an error window when adding the .ts file.
    Some tracks not recognized. This track was ignored. File name: "testfile.ts"
    All tracks (the video and 2 audio files) can be played back properly. However Adobe Premiere CC doesn't play the AC5 5.1 audio file.
    Two questions:
    1. Why does tsMuxeR show this error?
    2. Why doesn't Premiere CC play the AC3 5.1 properly?
    Thanks,
  2. What does mediainfo (view=>text) say about the .ts file ? It probably has some teletext/subs that were ignored by tsmuxer
    You said "All tracks (the video and 2 audio files) can be played back properly.", but then you say PP can't play the 5.1. So which is it? Or were you testing playback in another player / software ?
    Can you import the .ts directly into PP ?
    Do you have the sequence setting set to 5.1 audio ?
