    Mar 2011
    Paris, France
    Hello
    I downloaded an FLV video that VLC says has an 1,000 frame rate.
    Is it a known bug?
    Thank you.
  2. Member Cornucopia's Avatar
    It's probably VFR and VLC can't calculate it correctly. Show us the MediaInfo info...
    Mar 2011
    Paris, France
    Thanks. Here it is:
    Format                                   : Flash Video
    File size                                : 144 MiB
    Duration                                 : 59mn 54s
    Overall bit rate                         : 337 Kbps
    httphostheader                           : r5---sn-4g57kue6.googlevideo.com
    Video
    Format                                   : Sorenson Spark
    Codec ID                                 : 2
    Duration                                 : 59mn 54s
    Bit rate                                 : 264 Kbps
    Width                                    : 426 pixels
    Height                                   : 240 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 fps
    Bits/(Pixel*Frame)                       : 0.086
    Stream size                              : 113 MiB (78%)
    Audio
    Format                                   : MPEG Audio
    Format version                           : Version 2
    Format profile                           : Layer 3
    Mode                                     : Joint stereo
    Mode extension                           : MS Stereo
    Codec ID                                 : 2
    Codec ID/Hint                            : MP3
    Duration                                 : 59mn 54s
    Bit rate mode                            : Constant
    Bit rate                                 : 64.0 Kbps
    Sampling rate                            : 22.05 KHz
    Stream size                              : 27.4 MiB (19%)
    Writing library                          : LAME3.98.2
  4. Member Cornucopia's Avatar
    Nope, not VFR...
  5. DECEASED
    Jun 2009
    Heaven
    Originally Posted by Chikuzen
    Timescale of FLV format is 1 millisecond.
    Thus all ntsc videos (xxxx / 1001 fps) are converted to VFR.
    source: http://forum.doom9.org/showthread.php?p=1492903#post1492903
  6. Member Cornucopia's Avatar
    Wow, I guess I was on the right track after all.
  7. Yes, sometimes FLV from the net are encoded in this way,
    there are not really 1000 frames every second, but dummy frames are added, a dummy frame doesnt carry any real vid info, just say to repeat the former frame.
    Mediainfo just does not consider these frames, thus showing only the real frames per second.
    Dont know why, maybe to make any re-eding more difficult,
    Or, if you have two clips one of 25fps, and one of 30, to join them you can losselessy convert both to 150fps with dummy frames and then join.
    I would like to know if there is a tool able to strip out the dummy frames restoring the original fps?
